Changing Rear Diff. How HARD??? 77 Vette
Old Oct 11, 2007 | 07:00 PM
VictoriaVette's Avatar
VictoriaVette
Default Changing Rear Diff. How HARD??? 77 Vette
Can I get some info from you all on how hard and how long it should take to change my rear diff?
Old Oct 11, 2007 | 07:26 PM
Gordonm's Avatar
Gordonm
are you just swapping one for another or rebuilding yours. Just swapping I can do mine in under two hours, but I have zippers on it by now. I have done it many times. You will run into frozen or rusted bolts so the time will increase. I would allow 4 to 5 hours for just a swap. A rebuild will take days.
Old Oct 11, 2007 | 07:28 PM
GTR1999's Avatar
GTR1999
1-1 swap vs rebuilding yours?
If it hasn't been out since the day it rolled off the line then you may have some rust seized parts to deal with. If it comes apart ok then 2 hrs is about right.
Old Oct 11, 2007 | 07:37 PM
VictoriaVette
Just a swap out but the one in the car has never been out. Very clean underside not any rust but surface rust. Any tricks or anything that might make it easier?
Old Oct 11, 2007 | 07:54 PM
GTR1999's Avatar
GTR1999
1-Remove the exhaust
2-I remove the spare tire compartment
3-Rear spring but it can be dropped with the diff. I like it out of the way and 40 lbs lighter.
4- Mark the camber position
5- pull 1/2 shafts out of the way
6-pull strut rods
7-disconnect the pinion joint
8- place a jack under the diff about 1/2" below it
9 remove the cross member bolts from the frame
10 - Use a long bar to pop the cross member off the frame
11- lower the diff and cross member down and out
There are some short cuts to do this as well but that is how I do it.
Suggestion: if you have a rebuild unit fine but it you're swapping in a used one you might want to check it out first. Seals, yoke endplay, posi case, backlash are all things I'd look at.
Old Oct 11, 2007 | 08:32 PM
VictoriaVette
I am replacing it with a rebuilt unit new 3.70 ring and pinion with carbon fiber clutch pack and plate set, HD springs set, new yoke , GM stub axles, HD rear cover, Timken bearings, I'm going to use Mobil 1 with GM additive.
Is there a good way to check rear wheel bearings while I do this? The car has 51000 miles.
Old Oct 12, 2007 | 01:11 PM
GTR1999's Avatar
GTR1999
you might want to add 2 bottles of GM additive with your fiber clutches.
I personally don't like those but wish you luck.
Old Oct 12, 2007 | 02:01 PM
VictoriaVette
Please reply and tell me why you don't like the carbon fiber disc I would like to hear what you think!
Old Oct 12, 2007 | 02:08 PM
Vesa's Avatar
Vesa
Why 2
Vesa's Avatar
Vesa
Me too.
To Changing Rear Diff. How HARD??? 77 Vette
