OOPS!!!, and yuppers, from that pix there they look non vented, fine for drag use as stated, you get into the twisties.....well, ask Van Steel, he will surely pop in here....
I do have them for the street but I haven't tried them out yet so I didn't put them up on our site. We like to try parts out before we give the go ahead on it. The rotors are a 2 piece design and are drilled and slotted. I'll try to dig up a pic and post it here but I can't comment on how they will work. The drag kit is pretty sweet and can cut about 56 lbs off the front end. The street kit will have similar weight savings too.
how can i get a price. and a ETA. i need 1/2 studs
The kit is expensive IMO. The kit alone is $815.00 and it's about a week turn around. We need your spindles to build it. If we supply spindles it's an extra $150 and I will need you old ones back. You will also have to use safety wire on the spindle nut. Cotter pins can not but used.
GrandsportC3 (Olivier) I believe gained 1/2 sec in the 1/4 mile and 2 tenths off the 60ft times.
