Take caution with half shafts.
DO BOTH AT THE SAME TIME!!!
Lightly start the bolts in the wheel side then fully seat the U-Joints in the yolk side. then evenly tighten both wheel sides.
This will keep everything in line by not pulling anything to far from side to side.
I did this recently and it eliminated the last bit of wheel wander I was having. I thought I may have gotten a bad alignment but after installing my shafts this way, my car is now(finally) better than new!
I am surprised that I have never heard of this before!
Mark
I have always had some side wander in the car, even after a good alignment. After doing it the revised way I find that all the road wander has been eliminated.
In the past I may have tightened the wheel bolts first and then tried pulling the U-Joints to the diff and maybe they were not fully seated hard to say!!!
But..if you loosen camber adjusting nut without scribing a mark first, you can mess up alignment...
Rich
I guess all I am saying is that when I replaced the shafts when all the work was done the car rides flawlessly!
I just attributed it to installing the shafts the "correct" way. Perhaps it was something else.
It sure is a pleasure to drive without that last bit of wander!!!!
Mark
