manifold/carb clearance
Old Oct 14, 2007 | 07:24 PM
kessler's Avatar
kessler
Default manifold/carb clearance
I have a 71 BB that I installed a edlebrock performer intake on. It has the quadrajet carb installed with a drop down aircleaner. The aircleaner is hitting the hood. The filter is about 3 inches thick. The carb has a gasket installed that is about 1/8 inch thick. I need hood clearance. I remember reading on this forum that the edlebrock intake with a dropdown air cleaner would fit under a stock BB Hood. Need some help........thanks!!!
Old Oct 14, 2007 | 07:51 PM
agent kronus's Avatar
agent kronus
I'm using LT1 base lid, which gives a 2 1/2inch drop, leaves loads of room on my 78 vette
dave
Old Oct 14, 2007 | 08:52 PM
trw's Avatar
trw
dave
Are you using a Holley or a Q-jet.
Terry
Old Oct 14, 2007 | 09:55 PM
SteveG75's Avatar
SteveG75
dave
A BB is much taller than a SB. You are comparing apples to peanuts.
For the OP, try a 2" tall filter and replace the lid with a K&N filter lid to restore flow.
Old Oct 15, 2007 | 04:03 AM
agent kronus
Terry
Im using a holley, but the q jet and holley are nearly the same height, and im using a 3 inch filter
dave
Old Oct 15, 2007 | 07:50 PM
kessler's Avatar
kessler
Ok, the carb almost hits without filter. What about gasket for Q-Jet, do they have smaller ones??????
To manifold/carb clearance
