Carb or Dist prob??? please help..
Old Oct 15, 2007 | 02:11 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default Carb or Dist prob??? please help..
I have a 77 350 l48 stock. with a Qjet. new plugs and wires,fuel filter.
I seem to still have a stumble or hickup.. When i hit it ,its like the car is getting either 1.no gas and almost dies, and i have to feather it to get speed. 2. getting too much gas and flooding?? 3. maybe my timming is off just a hair 4. or maybe the carb needs to be rebuilt......
Other than that the car runs great real strong.
Any ideas?? Was thinking i just need to have carn rebuilt by lars.
TIA George
Old Oct 15, 2007 | 02:15 PM
Durango_Boy's Avatar
Durango_Boy
More than likely it's timing. Small adjustments are all you'll likely need.
Old Oct 15, 2007 | 02:21 PM
ptroxx's Avatar
ptroxx
I Was thinking the same thing.. Wish i knew what to do with timing.. I have no clue when it come to timing.
Old Oct 15, 2007 | 03:28 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
These guys "wrote the book" on timing. Well worth reading.
http://forums.corvetteforum.com/show....php?t=1430339
And yes....a carb re-built by Lars is money well spent. I have two !
Good luck...
Old Oct 15, 2007 | 04:26 PM
lars's Avatar
lars
"90% of all carb problems are ignition problems."
Before doing anything with the carb, make sure your timing is correctly set up with 36 degrees total timing, a correct vacuum advance control unit, and adequate intial timing with functional centrifugal advance. Once verified, if you still have a stumble, you either have a bad accel pump, a lean condition (multiple possible causes), or a loose secondary airvalve spring windup.
Old Oct 15, 2007 | 06:36 PM
ptroxx's Avatar
ptroxx
Thank you Lars.... Im going to have someone help me with the timing.... I have no idea what im doing when it comes to that.But i will be watching for the next time. . And then ill go from there.
Will keep everyone up to date.
Thank you very much for the help..
Old Oct 15, 2007 | 10:12 PM
EPF's Avatar
EPF
How would I go about getting my carb re-built by Lars?
Old Oct 15, 2007 | 11:04 PM
ptroxx's Avatar
ptroxx
I guess you could send him a private message and ask....
To Carb or Dist prob??? please help..
