Took the Vette out for a drive this past weekend. Came to a stop light and smelled what I thought was rubber. Didn't think much about it. But when I came to the next light, I pulled over, got out, and seen smoke coming from my drivers side rear wheel. The wheel itself was coated with brake dust.
It could be your emergency brake...jack up that side and try to rotate wheel..(you may have to remove wheel & inspect..).hopefully it is just a matter of re-adjusting your emergency brakes...
They have a bad habit after some years, of swelling internally, and passing the fluid down to activate with pressure from m/cyl...but restrict the return pressures badly enough to keep pads applied....
happened to me on my '72 here about a year? ago....
Rich
This could be it, maybe. And I will check it. However, my E brakes never worked for ****!!!
Sounds like you think, your caliper is sticking the brake dust from the e brake should not coat the rims as bad as you say . go to Auto zone buy two new calipers (Lifetime warranty Delco ) bleed em and check the ebrake for bad springs .
Thats what i was thinking also. Espeacially since my ebrake does not even work if I wanted it to!!
I am going to take yours and Batman's advice and change out the calipers and rubber lines!!
Here's what happened:
Changed out both rear calipers and pads. i bought new rubber lines, but I thought heck with it, the old ones are about locked on!! So I tried bleeding my new calipers, and sure enough the side that I originally said had locked up, I could not get a drop of fluid to come out. Sprayed a crap load of PB Blaster on the rubber hose fittings, waited an hour and then took it off. Sure enpough when I got the rubber line off, fluid was dripping from the open steel line. Put on the new hose and then it was no problem bleeding that side.
Again my thanks to those of you on the Forum that are much smarter than me when it comes to Vette problems!!!
my wheel on passenger rear is locked up as well but I have fully bled the system. I think it is my e brake. When i pull on the lever inside the car, i can see that the ebrake line is going taunt and releasing as it should. Is there anyway i can brake the ebrake free w/o having to take it apart?
Probaably not. You can try to re-adjust the adjustment wheel to loosten the shoes. Most times that wheel will also be locked up. You can tap on the lever at the top, driving it back to the unloaded position. Sometimes you can move it and release the brakes. This only works on those that are border line, not on the rusted solid jobs.
[QUOTE=desi;1562458980]I thought rears had steel line, not rubber? Am I missing something? I just did my 74 rears and I don't recall seeing any rubber lines?[/QUOTE
There is a steel line running from the master to the back of the car and then a short rubber hose, and then a short steel line from the rubber hose to the caliper. it has to have this short rubber hose because of the flexing up and down of the rear.
The rears are a bit odd for an independent suspension design. Instead of having the rubber lines connected directly to the caliper, the flex lines connect the chassis line and the hard caliper lines, somewhat similar to a solid-axle car or truck (though those usually only have one flex line).
