Muncie M20 or M21?
Question is, what's the difference between M20 and M21? Is it just the ratios for the first three gears (obviously the "OD gear"...I put that in quotes in lieu of our 7 and 8 speed trannys that are out there today...is still 1:1).
Question #2: Which one would YOU put in a mild 350 with a 3.70 rear end? More importantly, why? Real pluses and minuses. My gut tells me not to mess with the combinations the GM engineers used but the devil on the left shoulder tells me that it could be a way to gain some performance and not really hurt anything.
Thanks!
Anyone else?
What year trans?The earlier 20s were weaker w/a 7/8s shaft(63-69),compared to the 1 inch shaft of the 21s.All were 10 spline,even the 22 in 68/69.In late 70 all three went to 26 spine until the end of the run in late 74.
I would get a 21,if it's a 60s,or 70 model due to the shaft size,but I may be mistaken,but I believe the 65 396/425 horse vett had the m20,and they held.Don't overlook a Surep T10,either,just to have a muncie.They are good trans,too.
I have a 75 Super T10 that I would let go,and a friend w/a trans shop has a rebuilt 69 21,and a blank casing 68 m20 forsale,rebuilt.He want's a grand each,and I'd probably let the T10 go for 450.00,plus shipping.A M20 would hold what you are running,tho.Used ones are around 2-500.00,unless someone is doing the numbers game,and then they get you.
Year 1963-1965 Type: M20 Rings: None Ratio: 2.56 / 1.91 / 1.48 / 1.00 / 3.16
Year 1966-1974 Type: M20 Rings: Two Ratio: 2.52 / 1.88 / 1.46 / 1.00 / 3.11
Year 1963-1974 Type: M21 Rings: One Ratio: 2.20 / 1.64 / 1.28 / 1.00 / 2.27
Year 1967-1974 Type: M22 Rings: None Ratio: 2.20 / 1.64 / 1.28 / 1.00 / 2.27
Below would be the percentage of drop from one gear to the next:
M20 2.52-1.88-1.46-1.00 Drop= 25%-22%-31%
M21 2.20-1.64-1.28-1.00 Drop=25%-21%-21%
As you make the ratios closer you end up having to change the first gear ratio to end up with 1:1. An M21 should have a rear end ratio of 3.70 or greater for best drivability due to the tall first gear. In other words, the M21 will be harder to get rolling than a M20. The M21 was available only on high performance engines where the M20 was standard on engines up to the basic 4 barrel models but was also available on most high performance applications.
For racing, I use both transmissions. With my 4.11 gear, I like the wide for autocrosses so that I can get a good launch and then go to second quickly and leave it there, and have about 70 mph top speed. For road courses, the close enables me to wind out third a little more where if I had the wide I'd have to shift to fourth.
M20 for the street with a mild 350 and 3.70 gears. Ideal launch ratio in 1st gear is 10 to 1.The M20 and a 3.70 is 9.32 to 1.
In the post by ahoover, he shows that the for the first 3 gears, the ratio steps between the M20 and the M21 are about the same and it is only the M20's big drop between 3rd and 4th where you can notice a difference, so that is why the M20 is preferred for the street as you normally would not be in a situation where you are making a 3 to 4 upshift at max rpm and the lower 2.52 first gear gets you rolling easier.
The M20 could be had with 308 as well. So to answer your question it will work just where to you want to run RPM wise at 65 mph?
A side note. A buddy with a 76 and ST-10 (264 1st) had me build him a diff with all the mods. He had me install 273 gears. I thought those would be a problem starting off but he loves it. The speedo is off about 8 mph but he loves the gear.
When I raced with M-20's...I just made sure I wound 3rd gear a little higher to make up for the bigger drop into 4th. The other spreads are essentially the same as noted above.
JIM
Kajonjon.com has good info on parts and what is interchangable.
