Info on cam specs
thanks
used chevy just put 76cc chamber heads on later engines to drop compression. Cranes blueprint of the 327/300hp cam
RPM range 800-4500
.050 duration 195/202
valve lift .390/.410
LSA 112
If fuel milage is your biggest concern just stay with the cam you have,
if you want a mild up grade in cam consider cams with figures
something like these two.
Crane cam and lifters # CRN-113502
RPM range 1200-5200
.050 duration 206/218
advertised duration 256/268
valve lift .432/.459
LSA 112
advised comp. ratio 8.0 to 9.5
cruise rpm range 2200-2600
Crane cam and lifters # CRN-113512
rpm range 1600-5400
.050 duration 212/218
Advertised duration 262/268
valve lift .446/.459
LSA 114
advised comp. ratio 8.5 to 10.0
cruise rpm range 2400-2800
I'm guessing your 80 L/48 has 270s/3.08 rear gears, the first cam matches
the very low comp. of an L/48 better, may have the better
rpm cruise range for your gearing.
