Is this strut rod normal
Old Oct 20, 2007 | 05:28 PM
vette blue's Avatar
vette blue
Default Is this strut rod normal
Is there supposed to be that 1/4 inch gap in the lower strut rod as seen in the photo?
It is a stock 71 sb.[IMG][/IMG]
Old Oct 20, 2007 | 05:50 PM
...Roger...'s Avatar
...Roger...
Looks like the bushing is wore out.
Old Oct 20, 2007 | 06:08 PM
ltlevil's Avatar
ltlevil
Yep bushings are history, that's why the gap is there.
ltlevil
Old Oct 20, 2007 | 06:23 PM
Gordonm's Avatar
Gordonm
Time to replace. While your at it you might as well remove everything back there and rebuild it.
Old Oct 20, 2007 | 06:49 PM
vette blue's Avatar
vette blue
Thanks for your replies.
I was afraid the wrong strut rods were in there. I bet my trailing arm bushings look even worse.
My Bilsteins and strut bushings are coming in this week and I'll change those for now an see how it goes.
I've been spraying pb blaster on those strut rods for a week now and I hope they'll come out with no headaches.
Old Oct 20, 2007 | 06:56 PM
Bob Onit's Avatar
Bob Onit
How is the rear camber looking?
I just noticed some negative camber on my right rear and I'm seriously hoping it's strut related
Old Oct 20, 2007 | 07:43 PM
ltlevil's Avatar
ltlevil
This goes without saying but be real careful when trying to get the struts apart. I broke one of the ears off my TA support which led to rebuilding both TA's, installing adjustable struts and half shaft loops.
ltlevil
Old Oct 20, 2007 | 08:44 PM
vette blue's Avatar
vette blue
Suprisingly the Camber looks good even though the bushings are worn. It was aligned by the previous owner some 5 years ago.
Maybe some of the experts can chime in, but I think the struts camber adjustment and new bushings may solve your negative camber. However I've been told that your differential yokes can affect it as well.Maybe somebody can confirm that.
Ltlevil I'm worried that I may need to pull out the sawzall, I don't want to hammer that support too hard. I figure 10 days of pb blaster and the shock mount removal tool "should" do the trick.
Old Oct 21, 2007 | 10:22 AM
ltlevil's Avatar
ltlevil
I had to use a cut off tool to get mine apart. First I cut the outer part of the stut rod then peeled it apart to get it out of the way. Then cut through the bushing sleeve and bolt. Hope it works out for you.
Old Oct 21, 2007 | 03:51 PM
...Roger...
Once you have the outer part peeled away use a razor and remove the rubber bushing if any is left.Then you will see the sleeve around the shock mount bolt.In the sleeve will be a "split",drive a small chisel in the split until it spreads open-shoot some PB in there.Now you have released the rusted sleeve from the bolt.The bolt should drive out without breaking the ear of the bearing support.
Old Oct 21, 2007 | 04:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The alignment might look good sitting in place, but worn bushings will move under load.
Old Oct 21, 2007 | 09:02 PM
vette blue's Avatar
vette blue
I hope I don't have to cut off the strut rod but just in case what type of cut off tool do you use? I have an angle grinder, would that work? I guess I better be prepared for the worse case scenario since that's the scenario that always seems to play out for me lately.
Thanks.
Old Oct 22, 2007 | 01:31 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Only do that if you don't have access to an oxygen/acetylene torch system. By burning out the old bushing, turning the strut rod sideways as much as possible, and heating the inner sleeve to cherry red, the shock mount should become easy to drive out using a 3/8 NPT pipe cap on the threads (don't ask, it fits). No need to be destructive.
To Is this strut rod normal
