Ground Strap on Head to Firewall????
Old Oct 20, 2007 | 07:17 PM
ddale1977's Avatar
ddale1977
Default Ground Strap on Head to Firewall????
Hello, finished my rebuild and I left off the ground strap that connects to the passenger side head. I've reattached it to the head now but where does the other end connect.
I can't find a stud or anything metal on the firewall? Does it go to the mounting bold on the wiper motor?
Doug
1977 350/auto
Old Oct 20, 2007 | 08:32 PM
Durango_Boy's Avatar
Durango_Boy
I have replaced all mine with custom straps so I don't know for sure but I seem to remember it going to the frame.
Old Oct 20, 2007 | 08:50 PM
bmotojoe's Avatar
bmotojoe
The only engine ground I know of is on the passengers side block to frame rail. There should be a threaded hole in the block forward a little of the starter. This ground cable is as large as what’s coming off the battery.
Brian
Old Oct 20, 2007 | 10:10 PM
AcuteViralDisease's Avatar
AcuteViralDisease
Cruising
Mine bolts to the underside of the engine mount
Old Oct 20, 2007 | 10:29 PM
Durango_Boy
Now that he's said that I remember very clearly that's where it was when I pulled the motor way back when.
Old Oct 20, 2007 | 11:48 PM
...Roger...'s Avatar
...Roger...
Are you referring to the braided ground strap that goes from the valve cover bolt to the ignition sheilding around the distributor?
Old Oct 21, 2007 | 08:48 AM
Red 69's Avatar
Red 69
That is it, look at the passenger side engine mount frame boss. On the front side there is a hole for it to be mounted to. It mounts from underneith and inside the cavity, as I recall.
Old Oct 21, 2007 | 09:24 AM
clarence-nieuwhof's Avatar
clarence-nieuwhof
There is also a ground strap that goes from the bird cage to the frame, on the drivers side just in front of the fire wall
Old Oct 21, 2007 | 09:37 AM
bmotojoe's Avatar
bmotojoe
Look at the 1977 Corvette Assembly manual. For around $20.00 the assembly manual is a good investment.
Brian
Old Oct 21, 2007 | 01:33 PM
ddale1977's Avatar
ddale1977
Thanks for the replies. I 'do' have the tround at the motor mount to the frame. Replaced it with a new one. Large gauge.
I have read on this forum about another ground (about the size of a pencil)....that goes from the passenger side 'head' to the firewall.
When I put my motor back. I had this pencil sized ground wire left over and trying to figure out where it goes. I know it is not the one that is on the bottom or the block.
The firewall is fiberglass so I can't see a stud to attach to.
Also, I'm still fighting getting my wipers to work.
I have the AIM....I'll look in there.
Doug
Old Oct 22, 2007 | 01:37 PM
SIXFOOTER's Avatar
SIXFOOTER
There is a ground stud on the firewall on the evap box. It collects the grounds from the Head, Wiper Motor and the main harness and ties them together.
The stud itself is not grounded as it goes thru the fiberglass firewall. The factory setup has it connected to the valve cover bolt, but I find that connecting it to the back of the head is better.
To Ground Strap on Head to Firewall????
