Radiator/ Front Spoiler
Old Oct 20, 2007 | 07:37 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Radiator/ Front Spoiler
I just finished flushing the radiator on my 79. When I emptied it the first time, there was about two gallons of coolant that came out. How much coolant should I put back in?
Second, I read about the front spoiler on the in another post. If I reinstall it, will I get better performance?
Thank you very much,
Doug
Old Oct 20, 2007 | 08:28 PM
Durango_Boy's Avatar
Durango_Boy
The amount of coolant will vary a lot based on the radiator. Just fill it with your preferred mixture until the level is about 3 to 4 inches form the fill neck on the radiator.
The chin spoiler is very important to shoveling air up through your radiator. It's a valuable component to the cooling system.
Old Oct 21, 2007 | 09:15 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
When your driving down the road, the spoiler forces air over the radiator so the fan can pull it through. Without it the engine will overheat or run hot, at best.
Good Luck!
Old Oct 21, 2007 | 09:41 AM
rihwoods's Avatar
rihwoods
Doug
Approx. 21 Quarts...I use 50/50 mix..
Old Oct 21, 2007 | 04:49 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My 77 never overheated without the spoiler, but it ran a bit hot. I noticed about a 10* drop on the gauge with it.
Old Oct 21, 2007 | 08:14 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The standard lower panel extension is not a true spoiler, and won't yield the performance gains associated with the '78-'79 Pace Car type spoiler and air dam aero package. It is, however, an important element of your cooling system that shouldn't be left off.
Old Oct 21, 2007 | 08:46 PM
mrvette's Avatar
mrvette
The front ends of these vettes are nearly identical frontal area, radiator, core size into the wind, from '68 to '82, the air gets there at 40 mph or over, spoiler or NOT, I have not once but many times demonstrated this in Florida....those spoilers are for SHOW, not cooling, I left the lower 'spoiler-deflector' from my '72 here years ago, tired of it dragging ground over every damn bump/driveway....
Old Oct 21, 2007 | 10:25 PM
TheSkunkWorks
Gene,
I don't believe you are, but if you are referring to the Pace Car package, I have to disagree with you. They were engineered for the specific purpose of enhancing the '78 Corvette Pace Car's high speed handling capabilities, and are indeed functional (lowering drag coefficient by approx. 15%). I don't have manometer readings, but after installing them on my SA, in one particular sweeper my shark went from dodgy at 95mph to flat-out on rails at 120mph, with no other changes. Obviously a good measure of downforce was at work. Whether or not you've personally seen a difference in cooling (I did), these are not the results one should expect from a purely cosmetic accessory. Just wanted to clear up any possible confusion over these.
Charlie
To Radiator/ Front Spoiler
