Rear Coil Overs
Old Oct 22, 2007 | 11:03 AM
Petes73's Avatar
Petes73
Default Rear Coil Overs
Does any one make a conversion kit to replace the rear leaf spring with coil overs? I have seen them for the front, but have not been able to find them for the rear.
Old Oct 22, 2007 | 11:21 AM
Skunkvette's Avatar
Skunkvette
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Check with Van Steel.
I ordered the complete (all for corners) coil over conversion set up from them at Carlisle, still waiting for a few heavy duty parts to complete the order and start the tear down.
Old Oct 22, 2007 | 11:33 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Old thread
http://forums.corvetteforum.com/show...oilover+teaser
It's on my home page too
www.vansteel.com
Old Oct 22, 2007 | 11:54 AM
Petes73's Avatar
Petes73
Thanks, I am not ready to pull the trigger yet, but I'm thinking this is the way to go.
Old Oct 23, 2007 | 03:22 AM
Graemeinvette's Avatar
Graemeinvette
Speed Direct are developing an interesting rear coil over set up. Different from Van Steel's in that it uses the stock trailing arms and the coil overs operate on a bellcrank system, not out yet but due shortly.
Old Oct 23, 2007 | 06:46 AM
Stroker-427's Avatar
Stroker-427
The idea is not bad...... but due to the very short ratio of the rockers any end-play in the sistem can become an huge loss of control of the wheel.
I'm curious about the final release...... but as I have discussed with sme friend in the Forum.... the main concern is the effectiveness of the shock in that push-rod configuration.
To Rear Coil Overs
