Help building an L48
Old Oct 26, 2007 | 10:24 AM
thecorvette's Avatar
thecorvette
There is more than one production vortec head. The most desirable is the "L31" head. Part number 12529093. Casting number 10239906.
Old Oct 26, 2007 | 11:43 AM
desi's Avatar
desi
Originally Posted by billla
Drop...from 8.5? Why?
I meant, increase. You know what I mean
Old Oct 26, 2007 | 03:21 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by yel76low
Performer heads flow less than vortecs? I thought Edelbrock 'guarantees' 400hp with their top end kit?
Not sure how this will display, but here are the numbers. The exhaust numbers aren't a straight comparison because of the way the port blends into the chamber. Look at the idle to mid-range flow up to .500 lift (the stock Vortecs are lift-limited to .475) - this is where every CFM counts.
I'm not discounting the Performer heads at all - I'm just noting that for a set of really cheap iron heads the Vortecs are an amazing deal!
Key:
EDL = Edelbrock Performer #60609
VTC = Vortec #12558060
Lift EDL VTC
I E I E
.1 67 58 70 48
.2 130 108 138 101
.3 183 144 190 129
.4 226 169 227 140
.5 229 175 239 147
.6 232 128 229 151
.7
Old Oct 26, 2007 | 03:36 PM
billla's Avatar
billla
St. Jude Donor '14
P/N 12529093 is a bare head...
There are 3 GMPP heads; if you're going junking for heads it's a different story...and you're likely to spend more money than a NEW head:
  • 12558060: production assembled head, 170cc runner, 64cc chamber, 1.94/1.50 valves, ,.475 lift (upgraded heads available to .525+ lift)
  • 25534421: Bow Tie (aftermarket) "small port" assembled head, 185cc runner, 66cc chamber, 2.00/1.55 valves, .530 lift. Nice touches are dual pattern intake capability and center- or perimeter-bolt valve covers.
  • 25534431: Bow Tie (aftermarket) "large port" assembled head, 215cc runner, 66cc chamber, 2.00/1.55 valves, .530 lift. Nice touches are dual pattern intake capability and center- or perimeter-bolt valve covers.
