396 stroker - pros / cons
Old Oct 23, 2007 | 06:03 PM
71bridgehampton's Avatar
71bridgehampton
Default 396 stroker - pros / cons
For those who have done the 383 stroker build why would you not have stroked your motor to a 396? 396 Kits are available. What are the pros and cons of going to a 396?
Old Oct 23, 2007 | 07:32 PM
gkull's Avatar
gkull
The pros are that it cost the same if you are using a forged rotating kit. I have the block at the shop getting a blueprint and bore to 4.040 for 398 ci. 6 inch rod. this is drag race motor with domed pistons. The final compression is going to be 13.2. It will be a good time motor EDL VJ heads electric water pump two inch primary headers
Old Oct 23, 2007 | 07:44 PM
71bridgehampton
I am planning on mostly street use only / some highway - definitely not for drag race use - no high RPMs - is this overkill. Looking at 30 overbore - with this stroke will the RPMS required be higher with this motor?
Old Oct 23, 2007 | 07:47 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I don't believe there are any downsides to building a 396 vs a 383, besides costs. I have a running 396 (not in the car yet) and am very pleased with the outcome. The additional clearancing is minimal & the forged kit gives you plenty of leeway for nitrous, etc.
Besides you can get 396 emblems to put on the hood if you wish.
Old Oct 23, 2007 | 09:11 PM
dgruenke's Avatar
dgruenke
I went with the 383 because of cost. I got the cast crank with the hyper pistons. You can only get the 396 in a forged setup. If you are going forged anyway, it costs about the same for a 396 setup.
Old Oct 24, 2007 | 09:16 AM
gkull's Avatar
gkull
One of the biggest Pro's about 396 is the additional free TQ that comes with extra ci. It is @20 foot pounds over a 383 and about 60 more than 350.
So when air resistance goes up as speed increases the big ci motor can still accelerate.
To 396 stroker - pros / cons
