Info For 3 x 2 setup
Old Oct 23, 2007 | 07:39 PM
randyward's Avatar
randyward
Default Info For 3 x 2 setup
Just had the 3 carbs rebuilt on the 427 and am looking for the best resource (book?) for the proper final set up. Motor runs but coughs and sputters.
Rand
Old Oct 23, 2007 | 08:24 PM
GDaina's Avatar
GDaina
There really isn't much to set up, other than the air/fuel adjustment...gently turn in the two screws on the side of the metering block till they dead end, then back out 1.5 turns each. Get a vacuum gage and fine tune the adjustments where you get the highest vacuum reading on each side.
Adjust the float levels where the gas just starts to trickle out.
Use the #2 screw on the white cam and adjust the accelerator rod .015 clearance. You will have to play with the power valves, but start out with the 6.5 inch
Old Oct 23, 2007 | 08:29 PM
randyward's Avatar
randyward
Thank You!
Rand
Old Oct 26, 2007 | 03:16 PM
GDaina's Avatar
GDaina
Daaaah....forgot to mention, the accelerator rod clearance should be .015" when the accelerator is fully depressed...throttle blades fully open
To Info For 3 x 2 setup
