76 fuel tank connection
Old Oct 24, 2007 | 05:15 PM
pete44's Avatar
pete44
Default 76 fuel tank connection
Hello again...replaced the fuel sending unit in my '76...also changed out all flex fuel/vapor lines ...I have 2 flex lines on passenger side that of course hook to fuel sender (3/8" and 1/4" I believe)..I have one flex line on drivers side that hooks to fuel sender (1/4" I believe) along with fuel gauge wiring to sender..question is I have another 1/4" connection off drivers side of fuel tank that needs to hook to something..It is molded right onto tank and is beside fuel sender....Please help...Thanks,Pete
Old Oct 24, 2007 | 05:32 PM
Durango_Boy's Avatar
Durango_Boy
That might be the line to the vapor canister. There will be a hard line on the frame, that runs up to the front. If I'm right, the vapor canister will be under the brake booster on the driver's side.
However, if a previous owner has removed the vapor canister then you need to cap that nipple and use a vented fuel cap.
