What CS144 alternator do I need???
No, there are a lot of regulator differences. Make sure you get the one with the correct wiring as described in Z-Man's article here.
The plastic fan on the CS144 has a tendency to break vanes. I've found that the CS130 metal fan drops on and is almost exactly the same size. The SI fan is way too small.
Nevertheless, the one I found DID come with a metal fan.
http://www.napaonline.com/masterpage...mfd+-+Standard
Next, I need to rewire things and I'm a little unclear still, even after reading the above link with pics. Anyone have an actual diagram? splicing the 330 ohm resistor thing is a bit confusing. Does it have direction or can it go either way?
Hope to mess with it this weekend. Also, need a lower, 3 belt V crank pulley because I bent mine somehow and it wobbles.
http://www.idavette.net/hib/reman.html
"If you are unsure which adapter to use, measure the resistance of the exciter line. Disconnect the positive battery cable and the alternator plug. Connect an ohm meter between the #1 terminal on the plug end of the alternator harness and the end of the positive battery cable. Turn the ignition key to the "on" position and read the ohmmeter. If resistance is less than 35 ohms, use adapter #8078. If it’s between 35-350 ohms, use #8077. If it’s more than 350 ohms, you have excessive resistance somewhere in that circuit which needs to be repaired, first."
I figured out which plug-in-adapter to buy and then went ordered the equivalent part from NAPA. That way, I can use either a CS-144 or a 12-si alternator....if I ever break down somewhere weird.
I would recommend buying the plug-in adapter; you don't have to do any cutting/splicing, and it lets you have the option using 2 different models of alternators...mine cost less than 20 bucks.
Below are the 2 part numbers at NAPA:
http://www.napaonline.com/MasterPage...ical+Connector
1. Where does the batt wire go on the original wiring harness from the alternator?
2. Is anything else attached/spliced into this stock batt wire?
3. Where does the negative wire go on the original wiring harness from the alternator?
4. Do I need to upgrade the negative wire to 10 guage also or can I leave it alone?
5. Can I create a ground anywhere on the frame by sanding/grinding down a spot on the frame rails and then attach the ground wire? Could I use this for the alternator ground if I need to upgrade wire size?
6. I have dual spals (method to my madness with all the quesitons). Currently I attached them to the alternator batt terminal (I know very bad). So my thoughts are as follows....
Step A. Run new 10 guage alt batt wire to where ever it needs to go (battery or someplace else?)
Step B. Use old wiring harness alt batt wire for the spals power source? If the wire is good enough for 64 amps stock alternator and my fans are 30 amps each then should not this wire be okay for my fans, correct? Still need to figure out where the heck this original alt batt wire goes to thought I guess.
Basically what I want to do is run a new alt batt wire to where ever it needs to go and then possibly use the old all batt wire for my power source on my fans.
7. Can I ground my fans to the frame similar to question #5 above?
Ahh...you all confused yet? I know I am
Thats in my '71 so it may be different in your car.
There are some capacitors that you connect to the output terminal in a prallel arrangement that would eleminate the static noise in the radio. Also the static noise may come from the ignition components, thats why they are fully shielded in all Corvettes.
Run all your audio wires away from power leads, all my audio wires run down the passengers side and power wires down the drivers side. Be sure that ground wire to the alt is connected. One can make the argument that because the alternator is physically connect to the engine it is already grounded, try leaving off that ground wire and see what happens.
Here's my .02 worth...
1. On the original '69s, the batt wire went from the alt to the batt post on the regulator because they had external regulators. Then that same wire went to the positive post on the horn relay (just like all the newer units). This changed in about 1970 when alternators went to internal regulators on Vettes.
2. Well, a bunch of stuff splices at the regulator and horn relays.
3. The negative wire runs down and joins a "common" ground wire somewhere in that harness. It eventually gets to the frame but who knows where.
4. I'd clean it up real good and make sure the wire is not corroded. After all, the case of the alternator is grounded to the engine, and you should make sure the engine is really grounded well.
5. Yes. Yes, but you don't need to (see # 4).
6. Ehhh.....sort of... Take a look at the wiring on these pages - this is an excellent site, by the way. http://www.madelectrical.com/electri...evymain1.shtml
Read about the "original Chevy" wiring then look at the "new system." This is how most of the guys around here are wiring theirs. They even show how to wire the fan relays.
Last edited by Z-man; Oct 29, 2007 at 07:36 PM. Reason: For clarity and fluid flow of the beautifully chosen words.
1. The 'splice' for a corvette is under the dash, I believe.
2. The charge wire does not go through the horn relay on a '76 (my power wire for the horn has been disconnected at the splice under the dash and the battery still charges fine).
3. The cs144 is a '3-wire' alternator right? So the best of both worlds? Takes the voltage reading from the splice AND has 140 amps.
4. I was going to rewire the charge wire from the alternator to the splice under the dash and then to the battery with an 8g wire to increase my charging capacity. Do I need to do this for the cs144?
5. I do have a new engine side wiring harness that I could install, would this be sufficient?
CASE CLOSED.......
Where does the brown and black wire go on the CS 144 plug? Should I use my existing brown and black alternator wires and just hook them up accordingly? If not, what goes where exactly?
I'm being told that brown wire goes to "L" and the black wire is unused. Is this correct?
