A-arm upper/lower Pivot shaft bushing torque ?
Old Oct 27, 2007 | 07:13 AM
SARASOTA SAM's Avatar
SARASOTA SAM
Default A-arm upper/lower Pivot shaft bushing torque ?
My 1972 has V.B.P. poly graphite bushes in the upper A-arms and VAN STEEL poly (are these poly graphite also?) in the lower A-arms.
What is the correct torque in FOOT POUNDS that should be applied to the pivot shaft end bolts and large washer for each of these products?
Also is there a higher torque applied to the lower shafts and if so why?
Do i need to apply thread-lock to the bolts? (LOC TITE)
MULTIPLE REPLYS PLEASE IN FOOT POUNDS WOULD BE APRECIATED.
Many thanks SAM.
Old Oct 27, 2007 | 08:35 AM
Durango_Boy's Avatar
Durango_Boy
It may not be the right answer but I have always just torqued both top and bottom to 35 lbs, and I do use a dab of anti-seize on the threads.
Granted, I have not used poly, but I would imagine there would be little difference.
Old Oct 27, 2007 | 10:09 AM
jackson's Avatar
jackson
Default for POLY CA bushings ... not rubber
Do NOT use antiseize on endbolts if you have POLY CA bushings.
Instead, clean both ... bolt male threads & shaft female threads ... extra clean! ... then install bolts w/ Loctite and simply snug up ... this is for POLY CA bushings only!
Poly CA bushings are not bonded together like rubber ... the poly parts normally want to rotate during operation ... and want to rotate the end bolt loose too ... so poly needs Loctite on end bolts.
Old Oct 27, 2007 | 12:48 PM
SARASOTA SAM
My bushings were suplied with a flat end washer to replace the original concave washer(used on rubber bushes) and also a new split spring washer.I think they have to be torqued to a specified level so the large washer pushes on the innermost metal sleve/bush and against the pivot shaft collar to stop this sleve rotating.Obviously too much tightness could distort this sleve,compress the poly bush,cause binding and creaking noises.
Am i thinking right on this ? SAM
Old Oct 27, 2007 | 02:01 PM
BB72's Avatar
BB72
Not trying to be **** but I'm sure it looks that way. It's ft/lbs or in/lbs as far as torque goes.
Old Oct 27, 2007 | 02:47 PM
Bob Onit's Avatar
Bob Onit
1973 AIM says 45-55 FT lbs
Old Oct 27, 2007 | 03:01 PM
SARASOTA SAM
so right --- apologies corrected
Old Oct 27, 2007 | 03:02 PM
SARASOTA SAM
YES I AGREE BUT Thats for rubber bushings.
Old Oct 27, 2007 | 03:18 PM
Bob Onit's Avatar
Bob Onit
Guess it might be time to call VB&P and Van Steel
Old Oct 27, 2007 | 03:44 PM
SARASOTA SAM
Guess your dead right but its Sunday tomorrow was hoping after all the people who had converted to polly a definitive answer was known?
Could this be a reason for the dreaded squekes/groans experienced?
(p.s. were 5-8 hrs ahead in the uk so if have to hope i dont but may have to ring both on monday.)
Come on guys can move on tomorow with a definitive answer
riding the wild wind........ regards SAM.
Old Oct 27, 2007 | 03:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I don't think rubber or poly matters. I torqued mine to the center of the listed specification from my 77 manual and the bushings seem to move fine. Make sure to put some Loctite on the threads so the rotating motion of the bushings doesn't back the bolts out.
Old Oct 28, 2007 | 02:14 AM
Solid LT1's Avatar
Solid LT1
I just LOVE those poly bushing kits that dont have the serrated inner sleeves like a factory "Harris" type bushing, after a few hundred or thousand miles, EVERYTHING is LOOSE! The factory bushings have a serrated inner sleeve to LOCK the washer to the control arm shaft so nothing comes LOOSE during the life of the Vette. WHY HAVENT ANY COMPANIES FIGURED OUT THE BASIC ENGINEERING that went into our cars. Yes rubber rots over time, but control arms STAY PUT for the life of the bushing! My humble opinion and because of all the years I have skinned my knuckles on cars, I am entitled to it!
Old Oct 28, 2007 | 06:13 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's why they invented Loctite.
Old Oct 28, 2007 | 06:39 PM
SARASOTA SAM
Im a like getting my head around this point and thinkinging this is real valid comment.
SO FAR SEEMS 106 VIEWERS HAVE NO DEFINITIVE ANSWER TO MY INITIAL REQUEST? some one must know surely!
Old Oct 28, 2007 | 09:39 PM
chris75stingray's Avatar
chris75stingray
the guy who did my alignment (corvette specialist) said he always puts 35 lb/ft of torque on those.
Old Oct 29, 2007 | 09:17 AM
Durango_Boy
Looks like you had two good answers. See below.
Old Oct 29, 2007 | 09:39 AM
jontis's Avatar
jontis
I did that. Torque to AIM specs whatever that was. I think 35 foot lbs was adequate. This torque should not be applied to the bushing if I understood what I did. The parts subject to the torque is only the shaft, the bushing inner shell, the flat washer and the shaft bolt. The inner shell's length should be adjusted so the bushing has a very small play against the flat washer and rests without pressure. The bushing should also be cut so it doesn't rub against the shaft. I reused the old outer shells and prelubed some extra. Six months and not a squeek so far. Use disposable gloves, the high pressure lube is like glue. Loctite the shaft bolts or they can come undone. My control arm fell off because of loose control arm shaft bolts when I just bought the car. You don't want that to happen.
link to VBP's instructions on how to do it that I followed:
http://www.vbandp.com/instructions/31015-16-27-28.pdf
To A-arm upper/lower Pivot shaft bushing torque ?
