Oil Pan Recommendations
Old Oct 27, 2007 | 07:19 PM
SMH's Avatar
SMH
Default Oil Pan Recommendations
Looking at oil pans. I have a SBC 383 and need a 7 or 8 quart pan. It needs to be no deeper than 7 1/4" at the sump. I have one that has kickouts and it is 14" wide at the rear sump so it hits my headers. Looking at this one.
http://www.daymotorsports.com/product/1633/c/C159/#
Do you think this one will work?
Any other suggestions or proven ones that will work?
Old Oct 27, 2007 | 07:38 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'm running a Canton road race pan with Dynomax headers, and have good luck with it. 7 qt, 7 or 7 1/4" deep ... I can't remember. They have several to choose from.
Old Oct 28, 2007 | 11:22 PM
SMH's Avatar
SMH
Thanks I will check them out.
Any others have any suggestions?
Old Oct 28, 2007 | 11:51 PM
Solid LT1's Avatar
Solid LT1
You could try a Transdapt #3047 oil pan, I had one in my 72 LT-1 but had leakage issues. Hopefully issues are solved by now, pretty decent pan for the $$$ and good design for oil control. I use Canton pans now but not as happy with oil control in the Canton pan I presently use. Summit has them, here is a link to TD; http://www.tdperformance.com/TransDapt.html
Old Oct 29, 2007 | 01:22 AM
l88rocket's Avatar
l88rocket
Stef makes a good pan.
Old Oct 29, 2007 | 03:08 PM
jackson's Avatar
jackson
That one at Day is probably gated for left hand turn circle tracker ... pickup probably dips right ... neither not best choice for street ...you need a pan that's gated for road race and uses a pickup that's centered.
Take a look at Champ pans ... you probably won't see their RR pans on their site but they have em www.champpans.com ... also check out www.cvproducts.com (they sell champ & others). If you have a welder & KNOW what you're doing ... you can mod a circle pan for RR/street ... you fab&add a gate to right side & use a center PU.
Old Oct 29, 2007 | 03:19 PM
Scott Marzahl's Avatar
Scott Marzahl
I like Aviad pans. http://www.aviaid.com/
To Oil Pan Recommendations
