horn does not work
Old Oct 29, 2007 | 04:00 PM
Z-gman's Avatar
Z-gman
Default horn does not work
My 69 vert had a 76 vega wheel, t&t, got all the parts from a vet parts dealer to convert to correct wheel, here is my problem...the horn button sits against the telescopinc adjuster and the horn button is not long enough to touch the contact point what am I missing? Thanks in advance
Old Oct 29, 2007 | 04:04 PM
Durango_Boy's Avatar
Durango_Boy
Do you have the spring under the pin to push it up into contact with the horn button contact?
Old Oct 29, 2007 | 04:06 PM
Z-gman's Avatar
Z-gman
The spring is in but it has a piece on the end to hold it down right?
Old Oct 29, 2007 | 04:08 PM
Durango_Boy
Yeah the pin goes in the bore and there is a spring under it to push it up. Maybe someone will have a good exploded view of the column and you can see what might be missing based on what you put in when you assembled it.
Old Oct 29, 2007 | 04:14 PM
Z-gman's Avatar
Z-gman
looking at the manual I think I have everything and it is in the right place, the contact with the spring is it flush to the hub or does it protrude?
Old Oct 29, 2007 | 04:15 PM
Durango_Boy
If I remember correctly it should protrude.
Old Oct 29, 2007 | 04:18 PM
Z-gman's Avatar
Z-gman
Thanks Durango_boy that may be the problem
Old Oct 29, 2007 | 04:40 PM
76stingracer's Avatar
76stingracer
It does and I think it is there to hold it in place during assembly. I use the horn contact lever arm to push it down when I install the horn contact assembly.
Old Oct 29, 2007 | 04:42 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
could be worse..http://forums.corvetteforum.com/show....php?t=1850511
Old Oct 29, 2007 | 05:31 PM
dobroman2001's Avatar
dobroman2001
http://s189.photobucket.com/albums/z...eel%20removal/
Here's a link with some pictures that may help.... Good luck,
Old Oct 30, 2007 | 04:25 AM
RunningMan373's Avatar
RunningMan373
I don't know. i'm not phsyic. ever heard of a digital camera?
To horn does not work
