Pulled Both Front Wheels, But...
Old Oct 29, 2007 | 09:22 PM
nastee383's Avatar
nastee383
Default Pulled Both Front Wheels, But...
I went to test & tune Friday and the car pulled both front wheels about 2-4 inches on launch but immediately stumbled and then took off again. It has a 750 Speed Demon VS carb. The 60' was only in the 1.7-1.8 range because of the stumble. Any ideas on what is causing the stumble after pulling the front wheels on launch? This is not my Vette but I would appreciate some diagnosis'. Thanks
Old Oct 29, 2007 | 09:44 PM
Vette Crazzy's Avatar
Vette Crazzy
could be fuel sloshing up and out the front tube and dumping it in the rear of the carb. take a piece of 3/8 hose and connect it to each tube and make sure you put a hole in the very top of it
vc
Old Oct 29, 2007 | 10:28 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I had that issue. A rubber hose from the front to the rear vent tube that is open on top solved that problem!
Old Oct 29, 2007 | 11:47 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Sometimes you need jet extensions on rear jets. Or maybe just raise rear float level. Or lower front one....
JIM
Old Oct 30, 2007 | 06:35 AM
red79vette454's Avatar
red79vette454
We had the same carb and the same problem. The hose between the vents fixed it.
Old Oct 30, 2007 | 08:39 AM
Vette Crazzy
thats what i said. lol
vc
Old Oct 30, 2007 | 08:41 AM
GrandSportC3
vc
sorry, didn't read your response, just the initial post..
Old Oct 30, 2007 | 08:45 AM
fugawi's Avatar
fugawi
at least everyone is on the same page...
Old Oct 30, 2007 | 08:49 AM
Vette Crazzy
im just messing with you
vc
Old Oct 30, 2007 | 09:08 AM
GrandSportC3
For illustration - here's a pic of my old setup.. I hit 60' times in the 1.39 range and no issues..
Old Oct 30, 2007 | 03:24 PM
nastee383's Avatar
nastee383
Thanks for the replies. I was thinking about the fuel uncovering the jets and the float level being low but I didn't know about the hose deal. I'll try that next time out and go from there.
Ced
To Pulled Both Front Wheels, But...
