bbc cam selection
Old Oct 30, 2007 | 09:57 PM
brngrhd's Avatar
brngrhd
Default bbc cam selection
i have a 468 that will be going in to my 69 the car will have a tko trans in it a nine inch rear end it will be 60-40 street strip.
i'm looking for a cam that will complement this combo
468 cid
9:1 compression forged pistons
grumpy bill jenkins merlin oval port heads with head studs and mls gaskets
stock rods with arp bolts
scat 4340 crank
fully balanced
stock tri-power
hydraulic roller
the biggest problem is i don't know where the tri-power runs out of breath. i don't want a cam that is good for 6500 if the tri-power stops at 5500 or 7000 and 6000. my guess is a cam that is good to about 6,000 is going to be plenty. the cam that is in there is something goofy as far as i know has like .577 lift and low duration, not sure of .050 numbers but it was like 260ish advertised i think. stopped making power by about 5 and was down hill fast after that. that was with bigger heads and an demon 850.
Old Oct 30, 2007 | 10:05 PM
brngrhd's Avatar
brngrhd
also the car will have nitrous on it i found a tri-power plate set up to go with the bottle and noids i have already
Old Oct 30, 2007 | 10:09 PM
BB72's Avatar
BB72
I picked a Lunati Voodoo cam. The 60213. It's .629 lift intake and exhaust and 241 and 249 dur in/ex. Unfortunately I can't tell you how it runs because my motor is as you see it in my avatar, stuck on the stand. It should work good in a 496. It would seem a little more lumpy in a 468. It costs about $550 for the cam and spring kit which includes retainers and locks. It's a nice billet hydraulic roller.
Old Oct 31, 2007 | 11:43 AM
brngrhd's Avatar
brngrhd
are those 50 numbers? that might not be a bad unit i am looking for a somewhat big cam just not anything that is going to be too big for the tri-power. don't want the cam to have the sweet power too high where the tri power can't go. but i want to have a nice lumpy idle
Old Oct 31, 2007 | 01:34 PM
BB72's Avatar
BB72
Yes, that's at .050
Old Oct 31, 2007 | 02:19 PM
DRIVESHAFT's Avatar
DRIVESHAFT
With only 9.0 to 1 compression, I think the Voodoo 60213 is a little large for you. I would step down one size to the 60212. Its .600" lift intake & exhaust. Duration @ .050" is 231 intake & 239 exhaust. Lobe sep. is 110.
Old Oct 31, 2007 | 04:18 PM
Little Mouse's Avatar
Little Mouse
Don't know anything about Nitrous never ran any, but the couple of cam
catalogs I have point to wide LSA cams if nitrous is used, 112 LSA
or wider.
Old Oct 31, 2007 | 06:41 PM
GOSFAST's Avatar
GOSFAST
Default Hydraulic Roller vs. RPM
Unless you have some "high-end" secret I believe you'll be "hard-pressed" to get ANY retro-hydraulic into that (high) RPM range mentioned. It's not going to happen just yet!
The SB's will go that distance, but not the "big ones"!
As of today, we are using 160# closed pressures and 380# open @ .714" lifts and we have only attained 6500 RPM "safely" on all the dyno testing we've accrued to date!
With a C.R. of 9:1 (?) in a small(er) BB, I would stay small(er) on the cam anyway!
Good luck!
Thanks, Gary in N.Y.
P.S. Haven't tried the "bee-hives" yet, can't get past the "single-spring-syndrome". It took us 30 years of "advertising", to get away from the
"singles", making it somewhat difficult, if not impossible, to sleep nights giving my customers "singles" again!!! "Lose" a single spring, "lose" your unit!
Old Oct 31, 2007 | 07:08 PM
BB72's Avatar
BB72
Good luck!
I have read that hydraulic rollers don't rev too high.
Old Oct 31, 2007 | 07:46 PM
brngrhd's Avatar
brngrhd
again i think that 6,000 should be fine for rpm. are you saying that it will not turn that?
Old Oct 31, 2007 | 08:58 PM
Steve439's Avatar
Steve439
You can go 6K with a hyd roller. Tri-power will be fine.
That 9 to 1 compression is leaving a lot on the table for a 40% strip car.
You might want to look into milling the heads or something...
Old Oct 31, 2007 | 09:09 PM
brngrhd's Avatar
brngrhd
this is just what i was told it was i will be pulling the heads to install mls gaskets so i will check piston numbers and quench area then i will have a better idea what is going on.
To bbc cam selection
