1981 Gauge Problem
Old Oct 31, 2007 | 04:33 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default 1981 Gauge Problem
What do you think this problem is. Turn on the headlights or parking lights and the fuel and amp gauges go all the way to the left. Fuel goes to empty and amp goes to 40-.
Turn the lights off and everything works fine.
Old Oct 31, 2007 | 04:45 PM
SIXFOOTER's Avatar
SIXFOOTER
You have some grounding and bad connection issues in the center dash
Old Oct 31, 2007 | 08:05 PM
jdp6000's Avatar
jdp6000
That sounds like a simple fix. Your plug in the back of the center guage cluster has probably shifted. Light circuit is making contact with guage circuit. simpler then is sounds...one prong on the plug is probably touching 2 stands on the circuit board.
Easiest way to fix is by removing the center cluster. Unplugging the harness. Plugging the harness back in. Testing with lights on while is unassembled. then ressemble.
Or try the bubba way. Reach your hand up around the back...probably have to remove one of the side panels or stereo and give it a gentle wiggle.
Jim
Old Oct 31, 2007 | 08:55 PM
Corvette ED
That sounds like the problem Jim.
Old Nov 1, 2007 | 08:00 AM
jdp6000's Avatar
jdp6000
I had the same problem. Let me know how you make out.
Jim
To 1981 Gauge Problem
