Easy headlight question
Old Nov 17, 2001 | 05:59 PM
Ace77's Avatar
Ace77
Default Easy headlight question
I assumed this would be in the AIM, but it doesn't look like it is...
Are the highbeams the inside or outside lamps?
Are they the three prong or the two prong bulbs?
Thanks,
Jim
Old Nov 17, 2001 | 06:10 PM
The Wanderer's Avatar
The Wanderer
Default Re: Easy headlight question (Ace77)
Never looked.... but as with all other cars.... the inners should be the high beams! Don't know about the connectors.
Old Nov 17, 2001 | 06:14 PM
paso's Avatar
paso
High beams are the inside bulbs and are two prong. The outside lights have three prong as they have both high and low beam capabilties.
Old Nov 17, 2001 | 07:58 PM
micks69's Avatar
micks69
Default Re: Easy headlight question (paso)
Funny you should ask! I just looked at mine today and on my 69 the inner are the low beams and the outer are the high beams This I know for for sure!
Old Nov 18, 2001 | 09:44 PM
WATTAC's Avatar
WATTAC
Actually the info is in the AIM, in the wiring diagram, UPC 12, page D1. The additional "high beams" are the two inside lights with two wires/two pins going to them. The outside lamps have three wires and have low beam AND hi beam filaments/lamps inside each.
Andy
Old Nov 19, 2001 | 12:31 PM
Ace77's Avatar
Ace77
Default Re: Easy headlight question (WATTAC)
Thanks WATTAC.
I looked at the assembly part of the AIM.
I didn't think to check the wiring diagram. :sleep:
Old Nov 19, 2001 | 01:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
WATTAC is correct. It's in the AIM if you look closely at the illustration. Hi inside; low outside.
Old Nov 20, 2001 | 04:30 AM
lou's Avatar
lou
I just went out and checked my 80, the high beams are the inside lamps, they hav two prongs. The outside lights are the low beams and have three prongs. I confirmed these results with my assembly line manual. :cheers: good luck lou
To Easy headlight question
