77 Rear Window Trim
Old Nov 2, 2007 | 09:15 AM
chucktn's Avatar
chucktn
Default 77 Rear Window Trim
Is there suppose to be a chrome trim around the outside of the rear glass on a coupe? The guy before me replaced the seal but it looks looks like it's missing something to dress it up and hide the seal and caulking.
Old Nov 2, 2007 | 09:58 AM
Binnie77's Avatar
Binnie77
No trim was used. The rear window was sealed flush with a butyl seal to the framework.
Old Nov 2, 2007 | 10:13 AM
chucktn's Avatar
chucktn
Default 77 Rear window trim
That's what I've go but it sure looks like it could use some sort of dress up trim.
Old Nov 2, 2007 | 10:15 AM
Durango_Boy's Avatar
Durango_Boy
A popular modification is to install a removable rear window from the early C3s. I think it cleans up the install a bit since it uses a rubber surround seal instead of the butyl caulking. It also gives you the ability to remove the rear window for better cabin air flow.
To 77 Rear Window Trim
