77 Sagging door handle
Old Nov 2, 2007 | 01:41 PM
chucktn's Avatar
chucktn
Default 77 Sagging door handle
77 with a sagging door handle on the drivers side. Is there a way to repair without having to remove the inside panel. Handle works fine..the chrome push part sags a little.
Old Nov 2, 2007 | 01:44 PM
Durango_Boy's Avatar
Durango_Boy
The spring is probably bad and needs to be replaced. The only way to do that is to remove the handle, and the only way to do that is to remove the door panel. It's not a fun project.
Old Nov 2, 2007 | 01:48 PM
Vette Crazzy's Avatar
Vette Crazzy
they make a repair piece for this type of problem. all the vendors carry them. its a flat v shaped tin piece
vc
Old Nov 2, 2007 | 01:51 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
vc
I don't believe the handle has to be removed for this. You just pop in the insert under the handle and it acts as a spring to keep the handle up.
Old Nov 2, 2007 | 02:47 PM
jbowles49's Avatar
jbowles49
Default V shape spring
The piece mentioned to in previous posts does indeed work well to stop the sag in the door handle, however be aware that your door handle will need replacing at some future date. The drivers side goes first for obvious reasons. Its not that bad of a job, just time consuming.
Good luck
Old Nov 2, 2007 | 03:45 PM
kdf1986's Avatar
kdf1986
The cheap quick fix is to use the V shaped metal tab that inserts into the door handle. This can be done from outside the car.
The good fix is to replace the spring that is attached to the handle lever. For this the door panel needs to come off, and the door handle needs to be removed.
kdf
To 77 Sagging door handle
