Carb question: Is this repairable?
Old Nov 3, 2007 | 12:32 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Default Carb question: Is this repairable?
I wouldn't worry about it, except that this is a valuable old Holley.
Old Nov 3, 2007 | 12:39 PM
knight37128's Avatar
knight37128
Old Nov 3, 2007 | 06:19 PM
murraybs's Avatar
murraybs
Definitely.
I had a Solex carb do something similar on an old Volkswagen and I whipped together some JB Weld for a quick fix. I'm sure the same thing would work here.
Old Nov 3, 2007 | 07:49 PM
The_Dude's Avatar
The_Dude
I thought about JB-Weld, but I was worried it could crack, and eventually chips would get sucked into the carburetor. What about aluminum brazing rod?
Old Nov 3, 2007 | 07:57 PM
noonie's Avatar
noonie
Tig
Old Nov 3, 2007 | 11:56 PM
Matt Gruber's Avatar
Matt Gruber
jbweld good!
i've used it 13 yrs on my carb fuel plugs. still like new.
Old Nov 4, 2007 | 01:29 AM
Bowerss2's Avatar
Bowerss2
take it to a shop and see if you can get someone to tig it up for you, if not jb weld does work well.
Old Nov 4, 2007 | 10:30 AM
jshug's Avatar
jshug
I have used aluminum brazing rod on a Holley accellerator pump housing for stripped out mounting screw holes and it worked great.
Just do a little practise brazing on some scrap aluminum and watchout you don't get the base metal to hot, also and put on too much and file off the extra.
Old Nov 4, 2007 | 10:40 AM
lars's Avatar
lars
Originally Posted by noonie
Tig
Nope. You can't TIG zinc die castings - it flat won't work: The zinc simply falls away as it comes up to temp. I've tried using several weld setups and shielding gasses. JB Weld is probably the best alternative for a low-stress area like that.
Originally Posted by jshug
Just do a little practise brazing on some scrap aluminum.
Problem is, the carb castings are not aluminum - they're a "pot metal" casting with a lot of zinc. It does not respond well to repairs like "real" aluminum. You might be able to fill a captured hole, like a stripped screw thread, with aluminum brazing material, but a clean fractured part like the one shown in the photo probably won't hold well with a brazing process - it will break off again, unfortunately.
Old Nov 4, 2007 | 12:05 PM
bahamasair's Avatar
bahamasair
Muggy weld will fix it. http://www.muggyweld.com/potmetal.html
Old Nov 4, 2007 | 03:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by bahamasair
To Carb question: Is this repairable?
