Engine will not start when hot
Old Nov 3, 2007 | 02:00 PM
Libertyedition's Avatar
Libertyedition
2nd Gear
Default Engine will not start when hot
I have a 74 with a 350 in it , It has a Fireball cam , 600 Holley , The cooling side is taken care of by two Kenlowe fans mounted between the nose and the radiator sucking the air out from the Rad these trip in at at around 180 and seem to keep the temperature on the guage constant. It has no other fans.
The problem is ,If I run the car for twenty miles or more then stop and turn the engine off , then try to start it again it will not start , the engine will turn over and If I pump the gas it will eventually splutter but not start, but just flatten the battery,
This is an inherited problem as I have owned the car for a couple of years but only just finished working on it to get it on the road and discoverd this on the first few runs.
I know you get heat sink on the starter but can you also get it on the carb, I've heard of adaptor plates being used to lift the carb off the mani just to help with heat problem.
Any help will be appreciated , John
Old Nov 3, 2007 | 02:35 PM
Durango_Boy's Avatar
Durango_Boy
Yeah, adapter plates or a correct heat insulator carb gasket.
Old Nov 3, 2007 | 07:16 PM
10sec75's Avatar
10sec75
If the car is turning over, it's not a starter proplem.
I would try shuting down the choke.
Sometimes the elec choke will come on even at running temp.
If it's adjusted real rich, you could be flooding the engine.
Old Nov 4, 2007 | 01:02 AM
highlander751's Avatar
highlander751
I had a simular problem to what you discribe. It turned out to be a bad coil wire. Thermal problems can be hard to trouble shoot.
regards,
Robert
Old Nov 4, 2007 | 04:28 AM
Libertyedition
2nd Gear
I dont have the choke hooked up, it starts fine in the cold without it, the electric side could be a possibility but I still think its a carburation problem, but on the other hand usually its what you don't think it is so I'll have a play with the electrics, thanks for the help.
Old Nov 4, 2007 | 05:31 AM
Stroker-427's Avatar
Stroker-427
Vapour lock !
The gas in your carburetor start to boil when you stop the car (thermal collapse) and even tha gas line will boil.
The net result is a fuel pump empty of gas and full of vapour.......
A solution (I did it on my old engine..) can be a "T" fitting in the fuel line to the carb with a very small purge hole (around 0.050") wich you can re-direct to the return gas line.
The flow capacity of the pump will not be affected by that..... but from a small hole a lot of vapuor can be purged!!!!
Old Nov 4, 2007 | 08:02 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Originally Posted by Stroker-427
Vapour lock !
Also make sure the fuel line isn't touching, leaning (or is very close) against an exhaust pipe or headers. When I was youngin, I had a VW Beetle and it did the VERY same thing until I realized the fuel line was resting against the exhaust manifold. It's an easy thing to have done especially with the limited amount of space in the engine compartment.
Good Luck!
To Engine will not start when hot
