Rear Suspension Upgrades
Old Nov 3, 2007 | 04:34 PM
Auto X 434's Avatar
Auto X 434
Navigator
Default Rear Suspension Upgrades
I am building my C3 for Road Race and I want to upgrade the rear suspension. Preferabbly removing the leaf spring between the rear wheels and installing a more modern suspension with upper/lower control arms, coilovers and a sway bar. Has anyone head of a set up like that? And where do I get the parts, or will I have to custom fabricate everything to fit from off of a C6 or something like that?
Thanks for your help.
~ Chris
Old Nov 3, 2007 | 04:50 PM
V-Twin's Avatar
V-Twin
Something like this?
Old Nov 3, 2007 | 08:47 PM
shafrs3's Avatar
shafrs3
Here's a good place to start...
http://www.guldstrand.com/scripts/pr...p?idproduct=80
Old Nov 4, 2007 | 10:32 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you don't want to fab up everything from scratch, Guldstrand's 5-Bar link is about as good a set up as you're going to find. IMHO, if you do decide to re-engineer the rear suspension, get a copy of Carroll Smith's "Tune to Win" and study it until you know it backwards and upside down or you stand a good chance that you won't accomplish anything resembling positive results. Of course, if you're simply going to adapt another design, you don't have to know all that stuff, but understanding it is worthwhile if you're serious about maximizing the handling of your shark.
Oh, and don't forget the front. There's a bit of sorting out needed on that end, too. Whatever you do, post up as you go so we can follow your progress. These are the kind of projects that keep pushing the C3 forward.
Old Nov 4, 2007 | 11:30 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Here's a site with some interesting ideas along this line.
http://www.sriiimotorsports.com/196382corvette.html
Old Nov 4, 2007 | 01:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
~ Chris
I believe the C6 still uses the transverse spring suspension.
Old Nov 4, 2007 | 02:08 PM
Auto X 434's Avatar
Auto X 434
Navigator
V-Twin. What you have pictures of is something like what I have been thinking of. That looks pretty custom fabricated is it?
Old Nov 4, 2007 | 02:09 PM
Auto X 434's Avatar
Auto X 434
Navigator
The guy who lives next door to me who has been building prostreet cars for a while. Has built a '71 chevelle which he crashed on the local highway. And is now building a '57 Chevy told me that link systems are more designed for the quarter mile strip rather than the slalom and wont help with traction on the turns. Is he correct? He tells me that I need a fully independent system.
Old Nov 4, 2007 | 02:15 PM
Auto X 434's Avatar
Auto X 434
Navigator
Does anyone have no where to get drawings of the C6 suspension system?
I have the '75 assembly manual and I find it pretty helpful.
Old Nov 4, 2007 | 03:40 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Read the "Search!" sticky, then look up suspension posts by Twin_Turbo. He's done some amazing work on that car.
Old Nov 4, 2007 | 04:49 PM
shafrs3's Avatar
shafrs3
Guldstrand's setup was built for road racing. Dick Guldstrand is known as the one who built winning road race C3's. Guldstrand is to a road racing C3 Vette as Don Garletts or John Force is to drag racing.
Unless you're a suspension Guru go with a configuration that has been proven.
Old Nov 4, 2007 | 05:04 PM
V-Twin's Avatar
V-Twin
Guldstrand did not design the 5 bar, it's a Bob Riley design and originated from the need to correct the horrible toe control of the trailing arm suspension.
Old Nov 4, 2007 | 05:11 PM
shafrs3's Avatar
shafrs3
I saw the Twin Turbo handle then it changed to V-Twin, so which one are you?
Old Nov 4, 2007 | 05:17 PM
Stroker-427's Avatar
Stroker-427
Very well...... more people doing some special rearend!!!!
I have designed this configuration:
and this is the status of the fabrication:
By the way, doing some calculation, I have seen that a similar design requires a spring with higer ratio!
Normally, with stock or aftermarket trailing arms, a 360 lbs leaf spring can be considered quite stiff...... but..... there is a "but" !
The stock TA can be considered as a third grade lever.... where the pivot is the...pivot, the wheel is the force applyed and the spring is the work done!
The lever has an efficency os less that 100% (nearly of 80%).... so it will result as a 450 lbs spring located on the axis of the spindle.
With the new configuration the lever ends in the pivot of the rods.... and the force is equal to the work!!!
...may for you, guys, that was well known..... but for me is a new thing!
Old Nov 4, 2007 | 05:51 PM
shafrs3's Avatar
shafrs3
Yeah, and there were many people who designed and built the Trump Towers but The Donald gets the credit, such as it is in our society.
V-Twin's Avatar
V-Twin
what you are talking about is known as the spring ratio and wheel ratio, the spring ratio operates at a certain rate vs. the wheel ratio, dependant on the spring position relative to the axis and the force arms applies.
EDIT, I was replying to Stroker before Dr. Phil here interrupted.
Old Nov 4, 2007 | 05:57 PM
shafrs3's Avatar
shafrs3
So which one are you?
To Rear Suspension Upgrades
Old Nov 4, 2007 | 05:59 PM
V-Twin's Avatar
V-Twin
Not this again, we have had this whole ordeal before. Just STFU and keep your insinuations to yourself
Old Nov 4, 2007 | 06:02 PM
V-Twin's Avatar
V-Twin
I never left here, I was put in moderation. I don't have to hide, but if you don't like having me around, just say so. Maybe I will leave so you don't have to be so upset anymore.
Old Nov 4, 2007 | 06:04 PM
shafrs3's Avatar
shafrs3
Not upset, it's your problem.
I don't mind, just post who you are and don't hide behind your brother's handle.
