Ceter bolt valve cover heads.
Old Nov 3, 2007 | 07:19 PM
busterpelvis's Avatar
busterpelvis
Default Ceter bolt valve cover heads.
Looking at some heads for my 80 350 . will these heads work?
Old Nov 3, 2007 | 07:34 PM
Durango_Boy's Avatar
Durango_Boy
Yep, direct bolt on. LT1 heads are the ones that won't fit, and obviously LS heads.
Old Nov 3, 2007 | 08:23 PM
busterpelvis
Thanks.
Old Nov 3, 2007 | 08:26 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
If they're vortec heads, your intake won't bolt on...
Old Nov 3, 2007 | 09:45 PM
Durango_Boy
I don't think they made Vortec heads in '80.
Old Nov 4, 2007 | 01:21 AM
ss4ever's Avatar
ss4ever
What casting numbers are the heads? Some of the centerbolt style heads are not worth putting on.
Randy
Old Nov 4, 2007 | 07:55 AM
Durango_Boy
Randy
This IS very true. Yes they will fit just fine, as you asked, but next comes the question of why and what the heads came off of. They may be choked and flow very poorly.
Old Nov 4, 2007 | 01:09 PM
rcread's Avatar
rcread
What are the numbers on the heads?
If they are Corvette L98 center bolt heads, they will have a 58cc combustion chamber. Your heads, stock, are around 76cc, I believe. So your compression ratio will go up over 10:1. You'll want to run 92 octane or higher fuel with these heads. Also, they don't have a heat crossover, so your engine may run a little rough longer since it will take longer to warm up. The fuel won't atomize quite so well with the cold air. The exhaust ports on the heads are raised a bit over stock, so your exhaust manifold port won't completely line up with the port on the head. Not ideal, but not the end of the world either.
Old Nov 4, 2007 | 09:51 PM
Avette4me's Avatar
Avette4me
No need to school me. He said looking at some heads for his 80. For didn't read as stock to me.
To Ceter bolt valve cover heads.
