1/2" wheel studs
Old Nov 4, 2007 | 07:42 PM
lvrpool32's Avatar
lvrpool32
Default 1/2" wheel studs
Those of you that upgraded to 1/2" wheel studs whcih ones did you use??
I am looking at th elonger Morosso ones, but they all seem to be 680 knurl...not the stock 480.
Nick
Old Nov 4, 2007 | 10:39 PM
Solid LT1's Avatar
Solid LT1
Use ARP much better quality than Moroso! Drilling rear spindles SUCKS! really hard material on spindles. Here is a link: http://store.summitracing.com/partde...5&autoview=sku
Old Nov 4, 2007 | 11:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The quality of the Moroso studs is just fine. Drilling the hubs sucks, it's made much easier with the Norval-o-Matic jig. Too bad only a handful of them exist.
Old Nov 5, 2007 | 01:14 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
After yanking some 3" x 7/16" studs out of a stub axle, I had 3" x 1/2" studs installed by Guldstrand when I ordered a set of trick stubs from him years ago, so I didn't have to go thru drilling... My only regret is that I didn't have the foresight to have gotten the ones with dogs on the ends. If you get full length threads, suggest you get long nuts with recessed threads.
To 1/2" wheel studs
