I just got off the phone with AFR and the tech there told me to stick with my 9.4:1 compression for the supercharger. He said that I would have more detonation problems running a .093 head gasket at 8.5:1 than if I stuck with my .041 head gasket at 9.4:1. He said that having proper quench was more important than having the proper compression ratio to avoid detonation. Is this true? What do you guys think?
Now I'm thinking that maybe I should keep my compression where it is and buy one of those methanol injection kits to run with this blower.
This is a repost but it wasn't getting attention so I figured I should start another thread.
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by Scott Marzahl
That is pretty well published and documented, too much quench contributes to detonation problems.
I believe too much quench clearance is implied here.
Just so happens that you can buy .039" thick Fel-Pro's. Put the piston at 0.000" with that and you're golden. When quench is about .060" or more, you're not only going to have a less efficient burn and be inviting detonation problems with compressions approaching the limits of the octane being used, but you'll also have a dirtier (emissions) engine.
