Now that the essentials (motor and trans) are installed, I can start to work on the other problems I have....
The ignition switch connector(rear of dash) is partially broken, and one of the wires has a seperate spade teminal which has to be carefully placed whilst ignition connector is manipulated onto the switch terminals.
Are the electrical connectors available individually? or is an entire wiring loom necessary...
Whle I'm asking, my hi-beam dip switch connector as been toasted at some stage, as it too is cracked and brittle.
I just finished rewiring my 68 front to back and those 2 connector plugs were still good on the takeout harness. If you want them, let me know and I'll remove them and ship them to you. Tom
That is a very generous offer... thanks.
I can not seem to find those connectors individually...
Let me know how much you want for them, and cost to send them over... it's a long way to Adelaide, Australia.
