1969 Big Block Codes
Old Nov 12, 2007 | 09:28 PM
zr1nut's Avatar
zr1nut
ZR1NUT
Default 1969 Big Block Codes
I would like some help on decoding this engine block vin tag area reads CE0 57946 no vin number on pad block casting 3963512
Old Nov 12, 2007 | 09:39 PM
Mike Ward's Avatar
Mike Ward
The CE means 'Chevrolet Engine' (not counter engine or crate engine as some will tell you) the 0 means it was built in 1970 and the rest is a simeple sequence number that is non-decomposable.
It could have been installed in the car as a replacement by the dealer under warranty, or it could have lived it's life under the hood of a dump truck until you came along. Only original paperwork would help.
The casting number is for a 427 from the '69-70 era.
In any case, it's not the original engine. sorry.
