1970 Muncie removal
Old Nov 9, 2007 | 04:48 PM
boat196's Avatar
boat196
Default 1970 Muncie removal
Will I need to remove the shifter assembly from the shifter bracket and remove them from the car in order to remove the tranie
Old Nov 9, 2007 | 04:52 PM
blue by you's Avatar
blue by you
yes you will
Old Nov 9, 2007 | 05:08 PM
LYLE's Avatar
LYLE
It all needs cleaned off so it will slip back in the soild crosmember far enough to get it out.
Old Nov 9, 2007 | 05:22 PM
ezobens's Avatar
ezobens
I've also found that by rotating the trans 90 degrees (so that the side cover points up) give you a lot more play room to push the trans back and clear the bellhousing to drop the trans.
To 1970 Muncie removal
