Crossmember Under Radiator Rust Out Problem
Old Nov 12, 2007 | 04:38 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default Crossmember Under Radiator Rust Out Problem
Has anyone used a #203015 corvette cental part on their 69-72 and how was the fit? I tried to post a link off their picture properties and it linked to the wrong pic.Thanks. Ron B
Old Nov 13, 2007 | 12:10 AM
itsonlyairandfuel
If no one has bought a reproduction crossmember, how did you restore that piece ?
Old Nov 13, 2007 | 12:25 AM
Gearhead74's Avatar
Gearhead74
This extract from a Vette Magazine article (Big Block from Hell) in the 90's may be helpful.
Much Ado about Core Supports
There were four core supports used from ’69-’72. To differentiate, measure across the radiator opening:
1) 19" hole p/n 3966591–low-performance, small-block, manual, no air
2) 21" hole p/n 3966597–all w. L88, ZL1, early ZR1, ZR2.
3) 26" hole p/n 3966594– small-block, air
–hi-po, small block, M20/M21 manual, no air
–small-block, automatic
4) 27.5" hole p/n 3966596– big-block, M20/M21 manual, auto
All of these are discontinued Chevrolet parts, however, a derivative of #4 (p/n 339176, introduced for model year 1973) was available. If you use it on a ’69-’72, you accept any cosmetic differences and drill two 1/4" holes to mount the fan shroud.
First, we hunted for a serviceable used core support. None was found. We looked at repairing the existing piece by removing rusted sections and welding in new material. Not. A better idea was a reproduction. Numbers 2-4 can be had from Eckler’s. As the Big-Block from Hell is a ’71 coupe; we ordered p/n 25155 which replaces Chevrolet’s 3966596. It’s identical to the original part and bolted in with no problems.
Old Nov 13, 2007 | 01:25 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It appears that he's talking about the frame crossmember, not the core support.
Old Nov 13, 2007 | 06:00 AM
itsonlyairandfuel
Thanks Gearhead, I don't know how many times I've read the BBH articles, But Batman is right, I am wondering about the crossmember beaneath it, they can look good and be paper thin from internal corrosion. Mine has pinholes and I'd rather replace it, both corvette central, and ecklers have them. I just have heard horror stories about reproduction part fit. Ron B.
Old Nov 13, 2007 | 07:39 AM
69ttop502's Avatar
69ttop502
You can easily take the crossmember off and have new metal welded in. It is usually in the corners where this bumper crossmember rusts out. Mine is rusty too and this is on the to do list.
Bill
Old Nov 13, 2007 | 08:23 AM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
Default cross member.
I have done both(repaired some and used a new repro one.) For the roughly 200 dollars that a new one costs it is a good deal and fits well.
You can repair yours if you want but depending on how bad it is it may not be worth it. Plus ,you may repair a bad spot ,and somewhere else where the metal is thin from the inside but you just cant see it yet,can rust later on.
The new one is the safe bet.
Old Nov 13, 2007 | 02:34 PM
theandies's Avatar
theandies
I used on but I can't remember if I got it from CC or ZIP. It fit good, direct bolt in with no problems.
Old Nov 13, 2007 | 07:23 PM
itsonlyairandfuel
I think I'm going with the corvette central 203015. It's not worth trying to buy used, you'll most likely wind up with an inferior piece. Thanks Ron B.
Old Nov 13, 2007 | 09:22 PM
bj1k's Avatar
bj1k
Mine was rusted in the corners on my 68. I cut out the rust and made metal pieces that fit flush and welded them in, ground the welds flush and painted it. You can't tell it from new. Took a couple hours to do the metal repairs. A lot cheaper than buying new.
Old Nov 13, 2007 | 10:12 PM
mrvette's Avatar
mrvette
EH, been 12 years now, I bought used for my '72 here, and it's still fine...course I cheated....drilled drain holes in the lo spots for the water that will for sure get in there to sit, NOT NOW.....
and also poured in a whole can of naval jelly....let it drip dry itself out....
12 years later, still good....
Old Nov 14, 2007 | 12:10 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default new ones
take a look at www.corvetteproducts.net, they have what you need.
Old Nov 14, 2007 | 12:20 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Crossmember, not radiator support...
Old Nov 15, 2007 | 02:11 AM
ctrain22's Avatar
ctrain22
I got mine from Eckler's and had no poblems at all. Good fit and surprisingly easy to install.
To Crossmember Under Radiator Rust Out Problem
