68 Brake Caliper question
Old Nov 13, 2007 | 01:17 AM
corvettejer's Avatar
corvettejer
Default 68 Brake Caliper question
I have a 68 Corvette and of course it now needs calipers. I believe they are the original parts. Is there a kit I can buy and rebuild them or somewhere I can send them to have them sleeved. Or are they not valueable enough to worry about being original. They have some stamped numbers that I don't remember seeing on my later C3 calipers.
Thanks Jerry
Old Nov 13, 2007 | 07:24 AM
DZRick's Avatar
DZRick
Jerry,
I'd keep anything with numbers.
VB&P has a rebuild kit part #11308 listed here http://www.vbandp.com/SearchResult.aspx?CategoryID=337
I ended up just buying new calipers and setting the originals aside for the next owner or to sell to someone doing a complete #s matching resto.
Old Nov 13, 2007 | 09:03 AM
wombvette's Avatar
wombvette
Thanks Jerry
They are not valuable enough to worry about, but if you are, you can have one of the outfits that does them to do yours. I think Lonestar will do that for you, probably others.
Old Nov 13, 2007 | 09:48 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I believe VB will sleeve your calipers for you as I think I checked with them several years ago. You definitely want to keep those calipers and have them stainless sleeved.
To 68 Brake Caliper question
