Speedometer Gears
Old Nov 13, 2007 | 03:26 PM
billsfan's Avatar
billsfan
Default Speedometer Gears
My speedo reads 20% low. I have an 18 tooth driven gear, 3.36 rear gears, and 235-60-15 tires. It makes no sense. An 18 tooth gear is the smallest out there. Am I missing something? By the way, it's a '76 L-48 with a 4 speed.
Old Nov 13, 2007 | 05:38 PM
OzzyTom's Avatar
OzzyTom
I had a similar issue with my speedo.... was reading about 30% low.
Mine was fixed by restoring the speedo drive mechanism in the gauge.
I believe the standard factory calibration is 1000 rpm cable speed should read 60mph. Try attaching a drill (with a known drill speed) to the speedo cable (gearbox end) and see what your speedo displays.
The speedo mechanism may just need a bit of lubrication, or recalibration.
cheers
tom
Old Nov 13, 2007 | 06:03 PM
Steve439's Avatar
Steve439
There are threads about this... Black Magic made a calculator you can use to see what you need. I tried it with your tire size and it says you need a 21 - if you have the large drive gear.
http://forums.corvetteforum.com/show...74&postcount=4
This thread (also by Black Magic) should tell you what drive gear you have:
http://forums.corvetteforum.com/show...eedometer+gear
Old Nov 13, 2007 | 06:41 PM
Duke94's Avatar
Duke94
According to this chart, you have the correct gear. Must be some other problem.
Old Nov 13, 2007 | 06:54 PM
5speeds's Avatar
5speeds
there is a 17 tooth gear... GM# 3987917 but I don't think it will get you there, you may have the wrong drive gear in the transmission.... a 7 tooth instead of an 8 tooth
Old Nov 14, 2007 | 02:58 PM
billsfan's Avatar
billsfan
Thanks guys. I guess I'll try to calibrate the speedometer first, then check the drive gear.
To Speedometer Gears
