My 454 with an Edelbrock carb won't start cold anymore.
When I looked, there wasn't hardly any fuel in the carb so I replaced the (mechanical) fuel pump and filter and carb filter to no avail. The line from the tank is also clear.
I can start it with a little gas poured into the top of the carb and then it will run fine.
Any guesses as to the issue?
Thanks!
