Driveshaft Balance???
Old Nov 14, 2007 | 06:40 PM
hugie82's Avatar
hugie82
Default Driveshaft Balance???
I drive alittle faster than I should but I have a vibration at 83 MPH + in an almost stock 82 CFI. I had the tires balanced on the mag setting and I even tried in the regular setting with placing the wheel weights towards the center of the rim on the inside. Both times I had vibs at the same speed. I don't want wheel weights on the outside of my rims if I don't have too! So I'm wondering if it could be my driveshaft or halfshafts? Have any of you had a shaft out of balanced?
Old Nov 14, 2007 | 07:03 PM
Z-man's Avatar
Z-man
Driveshafts can be unbalanced or it could be some misalignment due to worn U-Joints.. Is there some crud on the shaft? It could also be the tires.
If it were me, I'd try rotating the tires or putting both front tires on the rear and rears on the front. If the vibration changes to a different speed, it might be the tires. If it's at 83 again, it could be related to the shaft. Jack it up on some blocks and check everything under there for looseness.
Old Nov 14, 2007 | 07:14 PM
hugie82's Avatar
hugie82
I tried rotating with no luck. I should have added that it is sometimes worse than other times but its always after 83mph. I sometimes can change the vib alittle by giving or letting off the gas. Thanks
Old Nov 14, 2007 | 09:15 PM
hugie82's Avatar
hugie82
Do they make clip style wheel weights or are they stick on only?
Old Nov 14, 2007 | 10:52 PM
croaker's Avatar
croaker
First question did you do any work or mod's before it started or has it been there and your just trying to track it down. mine does the same I did a shaftbalance new joints new tires rims and wll drop a few more bucks before I find it I'm sure
Old Nov 15, 2007 | 08:55 AM
hugie82's Avatar
hugie82
Croaker I feel your painNo to the mods. I have original (99000mls)stock 82 rims,breaks and suspension with BF Goodrich 255/60-15. The vib has always been their sometimes worse than other times. Thats what I'm trying to avoid $$$$. It cost $8 to $10 a wheel to balance here in a BUBBA $hit shop. At the moment I am looking for a shop that can balance the wheel on the car(I heard of this style balancer) or a shop that has a real high speed performance balancer. What does your vette do?
Also are you running steel rallys or aluminum rims?
Old Nov 15, 2007 | 08:57 AM
rj8806's Avatar
rj8806
Have you always had the vibration or did it start recently? have you tried rotating the driveshaft 180* and seeing if that eliminates or changes the dynamics of the vibration?
Richard
Old Nov 15, 2007 | 09:01 AM
Elduderino's Avatar
Elduderino
Hugie, would you describe the vibration as a low frequency vibe, like someone playing on a bongo drum? Or a high frequency vibe like someone doing a roll on a snare drum?
I have a high speed only (90mph+) high frequency vibe that is driving me nuts. Sounds similar to yours. I have new tires, u-jonts, shocks, and spring. So its not that stuff. Im afraid it may be bearings or a diff?
Old Nov 15, 2007 | 09:33 AM
hugie82's Avatar
hugie82
Richard
Hi Rich, when I bought the car it had michelin MAYPOPS (may pop at anytime) and its had a vib but it started at a slower speed. Then I installed the BFGs and have had them on for the pass 5000mls. The vib was better and didn't start until 83mph+. I checked the drive shafts for play in the U joints, tail shaft,rear bearing, missing weights on the shaft and for any build up of crud and no I never rotated the drive shaft 180. The only problem I found was my pinion seal is seeping but no movement. As far as freq. of the vib. its a buzzing drown sound that I feel in the wheel and seat. I had a s-10 w/ alum. mags and it took about 5 or 6 times of using different balancing machines and rotating tires before I finally got rid of the vibs in that truck It seems like no one calebrates their balancers anymore!!! When I worked in the buisness every morning that machine was calabrated. Anybody know of a good name of a high speed balancing machine? Also do you guys think its worth the effort to rotate the shaft 180? I know the trans was rebuild years ago but everything else looks original. Sorry for the long post, I'm trying to get all possiblities out there. THANKS
Old Nov 15, 2007 | 10:28 AM
Elduderino's Avatar
Elduderino
Hi freq vibes are typically driveshafts, u-joints, and or engine or tranny mounts. Low freq vibes are typically wheels and tires out of round or balance.
So becausae you say its a high freq vibe, I would not think wheel tire balance, but drive line and mounts. To eliminate the drive line and mounts, try to make the vibe go away by putting the car in neutral. I know this sounds a bit dangerous to be going 90mph in neutral, but as the strain is off the drive train and the revs drop to idle, if the vibe is still there i would start thinking bearings. Wheel bearing or yoke bearing. This is where I am now, and there both expensive...
Old Nov 15, 2007 | 10:52 AM
...Roger...'s Avatar
...Roger...
Yes try the neutral test.Then try a diff. gear so RPMs will be at a diif level.If you cant lock overdrive out or lockup with the shifter you should be able to do it a diff way.I think on my 80 you could unplug the wire from the MAP sensor and it wouldnt go into lockup.
Old Nov 15, 2007 | 12:30 PM
hugie82's Avatar
hugie82
Thanks Guys, I'll try popping it into nuetral and see what happens? As far as being dangerous, I've done worse at 90
Old Nov 15, 2007 | 01:26 PM
...Roger...
Remember to let off the gas pedal.
Old Nov 15, 2007 | 04:37 PM
hugie82's Avatar
hugie82
Here is my report. Took it up to 90mph pop it in nuetral and the vib was still there with a slight change in intensity. I'm pretty confident it is the balance of the wheels. I called a freind at the STS tire and he said their crappy machines are only good for a 70mph balance and even worse on the mag setting (I knew that ) So for my next expensive trick is call up my BMW stealer and see what they use? Hopefully they will take care of me since we just picked up an X5 last month. Any other suggestions for a good balance? BMW going to rape me!!!
Old Nov 15, 2007 | 09:51 PM
croaker's Avatar
croaker
I'm running Crager SS's but I had stock aluminum same thing mine pretty much goes away if I stick the clutch and hold the rpm I do know mine is load related If I hold it in low gear it appears
Old Nov 16, 2007 | 05:02 PM
hugie82's Avatar
hugie82
Mines still their in neutral so I'm pretty confident is the wheel balance but if your vib stops I think I would check out the pinion bushing. Thats the only part I no of that torques up alot under load. Let me know how you make out. I called my BMW stealer the counter guy said he has to ask the service manager if they can work on a none BMW
Old Nov 16, 2007 | 06:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Did you have the tires balanced on a GSP9700 road force balancer? If not, you could have a harmonic vibration in the tire itself. www.gsp9700.com has a shop locater.
To Driveshaft Balance???
Old Nov 16, 2007 | 07:18 PM
...Roger...
Yours sounds like its RPM related.
Old Nov 17, 2007 | 10:27 AM
croaker's Avatar
croaker
It Is. One thing I'm gonna try one day is to try turning the drive shaft end for end it looks the same on both ends. Has anyone ever cured a vibe problem like this you always read about them but hardely ever hear of cures. Good luck hugie keep us posted
Old Nov 17, 2007 | 10:36 AM
murraybs's Avatar
murraybs
If it's more intense when you're in gear and decelerating (off the fueler) then it's definitely a driveshaft.
