Headlamp Help
Old Nov 14, 2007 | 06:47 PM
pdallen's Avatar
pdallen
3rd Gear
Default Headlamp Help
We have a 1979 'Vette. The high beams will not operate. The low beams will. We tried changing the high beam bulbs, still no luck... Any suggestions?
Old Nov 14, 2007 | 06:55 PM
Green73's Avatar
Green73
Does the "brights" indicator light come on? Have you checked your fuses? Tried a test light? Maybe bad luck with bulbs, maybe a bad switch, or just plain bad wiring. Try one of you low beam bulbs on the high beam socket first, or if you have an ohm meter, you can test the high beam bulbs with that.
Old Nov 14, 2007 | 06:57 PM
79 t-top's Avatar
79 t-top
Look for a kink in any of the wires running to the lights if none then try troubleshooting your dimmer switch.... the book says if High beam inoperatable and you've done the obvious switch out the headlight...the next step is the dimmer switch which I believe from looking at my diagram is also the turn signal switch as well... You'll have to remove the steering wheel according to the book.
Old Nov 14, 2007 | 06:58 PM
79 t-top's Avatar
79 t-top
sorry forgot to add...I'm having the same issue so I feel your Pain...
Old Nov 14, 2007 | 07:03 PM
ronkellogg's Avatar
ronkellogg
Default high beam
There is a plug under the dash on the side of the steering column that you should check. If not plugged in correctly the high beams won't work.
Old Nov 14, 2007 | 10:09 PM
pdallen's Avatar
pdallen
3rd Gear
Can you tell me exactly where this switch is? I have changed out the bulbs with new high beams. I am not sure where the switch is. Thanks for your help!!!
Old Nov 14, 2007 | 11:56 PM
79 t-top's Avatar
79 t-top
do you have a shop manual? I would suggest getting one or borrowing someones if you can... the dimmer switch is inside the steering colum housing
To Headlamp Help
