Lars...Will this really increase mpg
Old Nov 16, 2007 | 04:56 PM
73VetteKS's Avatar
73VetteKS
Default Lars...Will this really increase mpg
In a different thread, this link was provided as an option for increasing mpg. I drive my '73 as often as possible, and I would also like to increase the mpg, but I wonder if this will work, and what the down side might be. http://community-2.webtv.net/MATTGRU/carb/
Thanks in advance for your input.
-Jim
Old Nov 16, 2007 | 05:24 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
-Jim
If it did, its hard to believe there's no patent on this or carburetor makers didn't have this built into their carbs to begin with.
While I see Matt as a pretty knowledgable guy, I think this icon > comes up pretty frequently. Not that I could ever come close to topping his knowledge or prove him wrong, I tend to take his recommendations with a grain of salt, or wait for someone else I trust to concur.
Can anyone comment on Matt's claim?
Old Nov 16, 2007 | 05:53 PM
guitarcrazy02's Avatar
guitarcrazy02
I know there's been a lot of talk going around on it, but I haven't heard any difinitive yes's or no's on it. We'll wait and see what happens...
Old Nov 16, 2007 | 08:39 PM
LemansBlue68's Avatar
LemansBlue68
My guess is that the plywood spacer he fabricated saved more fuel by preventing any fuel bowl boil-overs than did blocking the passages under the base of the carb. Going from 11 to 18 mpg is a pretty drastic change, especially with 4:11 gears.
As a previous poster noted, I gotta give this one a too.
Old Nov 16, 2007 | 09:16 PM
...Roger...'s Avatar
...Roger...
You could be right about the plywood being an insulator.But what I believe he is working with is turning a manifold with 2 large holes into one with 4 small holes.The epoxy in the cross-over passages was 1 way.Using the 4 hole plywood spacer was his 2nd design.And the 4 hole 1/2" metal plate was his 3rd idea.I believe the epoxy gave 100% seperation and he said the 4 hole spacers provided aprox. 60% seperation.I think I have that right.I dont know if anyone else has tried this but come spring I think I'll give it a shot on my 78.Shouldnt take much time or money but might prove to be worthwhile.
Old Nov 16, 2007 | 09:25 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I may try this on my Big Block. Who knows, I might get up to 10 or 12 MPG !
Old Nov 16, 2007 | 10:33 PM
72ragtop's Avatar
72ragtop
LOL. u mean double digit MPG. Sign me up.
Old Nov 17, 2007 | 10:31 AM
Matt Gruber's Avatar
Matt Gruber
I've added a lot more info to my report.
I've always wondered what is wrong with those BB's that suck too much gas. I'm curious as to the cause. I wish I had one to test.
Old Nov 17, 2007 | 12:32 PM
LeMans Pete
Originally Posted by Matt Gruber
Q: Wouldn't there be a patent on this if it really worked?
A: As far as I know, there were patents, and they have expired. Every V8 I have ever seen, came from the factory with a dual plane and a 4 hole manifold. This is old school engineering, nothing new. Hot rodders have made it very clear, that they don't care about mpg, and aftermarket manifold makers have provided products that they want. Edelbrock sells a 4 hole spacer for those that want to reduce the effects of reversion and improve off-idle torque. It costs extra.
You said in your report that low end torque numbers go up. Is that not what hot rodders want? So if the old 4-hole manifold not only provided better MPG and low end torque, but hot rodders don't care about the MPG, then wouldn't they still want the 4-hole manifold for the torque???
If I go to Summits site, I don't see one 4-hole manifold. I see a bunch of twos, and a single hole.
Now how is it that your idea, which basically boils down to a 4-hole manifold, not only increases gas mileage over these manifolds, but you also claim gives better low end torque?
So are you saying it absolutely kills high end? If we slapped your car on a dyno, would we see it die around 4000 rpm?
Old Nov 17, 2007 | 01:02 PM
Matt Gruber
good catch! i deleted the poor wording, and added another Q. Within a month the report will be ready for publication.
my reason for wanting a bigger cam, is, it has TOO MUCH low rpm torque(before the mod), and i want to shift the powerband higher, so it won't spin the tires too easily. Now, the truth is, I can DRIVE it, and not let it drive me. Simply put, I have to ease down the pedal,not jump on it. This technique is apparently beyond most people, and they buy a single plane and jump on it.
And yes, my 61 has the original exhaust on it, and backpressure jumps up to 4.5 psi past 4500.
So i have always traded street manners for high rpm power. I love the sound of the stock exhaust. Zora Duntov made a record of the 61 and gave it out as a promo
the 2101 is idle-5500. it is not a drag strip maniold. 4 holes don't, imo, alter its' max rpm, how in the world can it?
the 2101 was a poor choice (too small)
i am much happier with the weiand 8004 on my 72. the stealth might be even better.
Old Nov 17, 2007 | 06:26 PM
LeMans Pete
I'm still confused. So you're still saying that you'll get better low RPM torque with a 4-hole manifold, and all you have to do is get a higher CFM carburetor to maintain higher RPM torque?
You got a bigger cam to move your powerband up the RPM scale, but then you modified your carb or manifold to give you more power at the lower end?
So... you're increasing your powerband... and increasing gas mileage???
Gruber, any negative notes??
Old Nov 18, 2007 | 03:21 AM
joehalford01's Avatar
joehalford01
regarding spacers, you have two kinds
one is an open plenum spacer, the other is the four hole spacer
the open plenum increase's plenum volume allowing more air into the manifold essentially which moves the powerband up
the four hole however does not do that, it allows the fuel to gain more velocity, this is because it has to travel further before it is allowed to dissapate into the manifold. the extra fuel velocity would make it more efficient and like everything else that makes the motor more effcient-results in better mpg. these are also advertised as a means of gaining low end torque......
Old Nov 18, 2007 | 08:41 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
Default Carb spacers
Interesting read I found while surfing the net. Granted BG is in the business of selling theses but at least it provides the concept behind them.
http://www.gnetworks.com/v4files/bar...h%20images.pdf
and an interesting CF article:
http://www.corvettefever.com/techart...nfo/index.html
Bob
Old Nov 18, 2007 | 01:36 PM
Matt Gruber
thanks Bob & joe
off-idle torque is not in the powerband, imo.
it lets u avoid downshifting as u slow down in traffic. helps it stay in OD too if u have it..
well i'm moving on to my next experiment, making my 61 steer easier.
Old Nov 18, 2007 | 02:11 PM
...Roger...
Make the steering wheel bigger.
Old Nov 20, 2007 | 07:38 AM
Matt Gruber
ideas keep pouring in, page updated AGAIN!
i am sometimes 10-20 years ahead of the crowd,
but this is rediculous
in '78 i went to true duals on my 76(sold in 1982) and cruise mpg went from 13 to 17.6
Guys here never check mpg and have NO IDEA u can get more HP WOT and higher mpg at cruise. And Nearly nobody knew(knows) how much the exhaust is worth
29 YEARS LATER
do these guys here live isolated in a cave
don't u guys know mpg is a routine HEALTH CHECK for ANY car?
Old Nov 20, 2007 | 09:02 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Bingo! velocity also helps the fuel stay suspended in the incoming air (atomized). My thoughts exactly. I went with a XR288 HR to pull up to my max efficient rpm and AFR 195 heads to give me good flow but keep my port velocity up. My VE is 100% between 4500 and 6000, and tripower to help fuel economy and still have the CFM needed to pull at the upper RPM's when needed. My manifold has 6 holes and I put 2 hole spacers on the 2 end carbs. My last tripower manifold was also a 6 hole design and I ran over 20 MPG with a built 327, 3.55 and ST-10. GM discovered this trick for more power and better efficiency in the 50"s and used it until 1969. The only reason they discontinued it was warrantee issues with the later vacumn secondary tripower setups, 1 minor vacumn leak, a bigger cam or any modification that changed your vacumn from stock configuration screwed them up. Back then a lot of guys that ran tripower sucessfully were converting them to mechanical linkages, IE mechanical secondaries. What Matt has done is basiclly 2 2bbls with individual ports for each barrel. He is running on a 2 bbl with 1 - 2 bbl dumper, mechanical secondaries.
To Lars...Will this really increase mpg
Old Nov 20, 2007 | 09:47 AM
Matt Gruber
63mako
a pleasure to read your experience!
Nice tripower
i only have bi-power
i owe u a beer!
Old Nov 20, 2007 | 11:18 AM
neuroclast's Avatar
neuroclast
Hrm. Well I'm willing to try this to see how it goes since I currently get <10mpg even with my 700R4 w/the 383. I have an Edelbrock 1903 Q-Jet, any links to what spacer I'd need? I have a 2" rise hood so I'm not worried about the height, I just don't know which to get.
-Josh
Old Nov 20, 2007 | 11:11 PM
63mako's Avatar
63mako
-Josh
tuning issues
