Top Dead Center
Old Nov 17, 2007 | 04:16 PM
A2vette's Avatar
A2vette
Default Top Dead Center
Is there something I can use to manually turn the crank to get number one to TDC?
Old Nov 17, 2007 | 04:40 PM
BKbroiler's Avatar
BKbroiler
You can turn the bolt on the front of the crankshaft that holds the harmonic balancer on. 3/4 socket I believe. It helps to take out some or all spark plugs.
Old Nov 17, 2007 | 05:07 PM
A2vette's Avatar
A2vette
Thanks. When I drop the distrubutor in I can tell the gears are matched but there is a 1/2 inch gap between the base of the distributor and the intake. What am I doing wrong?
Old Nov 17, 2007 | 05:19 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
What about if you've removed the harmonic balancer and don't have that bolt anymore
Old Nov 17, 2007 | 05:20 PM
Durango_Boy's Avatar
Durango_Boy
It's probably not mating with the oil pump shaft. Make sure they line up using a flashlight and a long flathead screw driver.
Old Nov 17, 2007 | 05:35 PM
A2vette's Avatar
A2vette
That worked, thanks. Do I start with #1 plug wire where the rotor is pointed?
Old Nov 17, 2007 | 07:58 PM
dmayhew's Avatar
dmayhew
Default try this
if the car is a 4 speed , put it in 4th. gear and you can push thre and that will slowly turn the motor. Remove the plugs and it turns even easier.
But 4th is easier than 1st. Same for push starting if battery is dead.
Use 4th. not 1st.
If automatic , forget everything I said
David
To Top Dead Center
