383 short block help
have information or suggestions on the two short blocks listed below?
MLL-BP3830 Blue Print Engines GM 383 CID Short Block Stroker Engines
Crate Engine, Short Block, Chevy 383 Small Block, Cast Crank,
Flat Top Pistons, Driver Side Dipstick.
MLL-BP3831 BluePrint Engines GM 383 CID Short Block Stroker Engines
Crate Engine, Short Block, Chevy 383 Small Block, Scat Crank, .200 in.
Dome Top Pistons.
The heads and cam I have are listed below, any thoughts on them working OK with the above short blocks?
Heads EDL-60899 Edelbrock Performer RPM Cylinder Heads
Cylinder Head, Performer RPM, Aluminum, Assembled, 64cc Chamber,
170cc Intake Runner,
Cam CS 268H-10
Gross Valve Lift 0.454 0.454
Duration At 0.006 Tappet Lift 268 268
Valve Timing At 0.006
Open Close
Intake 28 60
Exhaust 68 20
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 218
Lobe Lift 0.3026 0.3026
Lobe Separation 110
You may want to do an additional search, as I didn't exactly go through with a fine tooth comb. Looks like a good value, though.
Pease
The 170 ports are too small. So is the cam.
