I am trying to replace door lock cyl.......I have a 79 and it is becoming very frustrationg as I seem to have very little room to work...any tips on making this easier?
Use a flat blade chisel and place it against a piece of the door skin.
The use another flat blade screw driver, place the screw driver betweet the chisel and the spring tab on the lock retainer.
Then twist the screw drive and it should push the retainer out of its slot. Do not pry it all of the wat. The take long needle nose pliers and get it the rest of the way.
