Top Hinge Pin Removal
Major PITA. The new pin appears to have to be installed up through the bottom of the hinge.
edit -oops sorry I see your doing it without removing the hinge.make sure the hole that the bushing goes in is still round.
Thought I could do this without taking the door off, but after trial and error, decided it was the only way.
1. Remove upper hinge cover and loosen the 4 bolts.
A. Make sure to have a box or support underneth door.(I used a box and was able to rest door against a wall in my garage.)
2. You have to remove the door panel to get to the bottom hinge bolts.
Once panel is off, and door is supported, loosen bolts and remove all upper and lower hinge bolts. I had read a previous post that you should grab a spray can a shoot the bolts for easy install of your bolts for alignment, however, after installing bolts back in I found that I still needed to loosen and adjust positions of bolts several times for proper door spacing and latching.
3. Once door was off, I used a punch or screwdriver to drive the pin up and then used a dremel to cut the pin in half, like durango_boy suggested. After installing new bushings, I couldnt figure out how to install new pin without damaging the fiberglass so I just ended up using my dremel (love that tool..!!!) and removed about half the lip on the new pin and installed easy after that and pressed the new pin down through the pin holes.
4. Now just reverse the procedure and (this was the worst part for me) slide the door back on the hinges..(I did this by myself). Took a few good cuss words, but finally went back on.
5. Now just check your alignment and loosen and tighten several times untill you get the best fit.
Hope this helps......
Happy Thanksgiving everyone...
God bless America....
So you bought Help! pins and bushings and not Vendor stuff?
Hmm...that'll save me some time. I may have you come in with me on this project.
