Speedo goes WOT!
Old Nov 21, 2007 | 12:50 PM
Muddywaters's Avatar
Muddywaters
Default Speedo goes WOT!
For the last few outing's, and only durring the first 3-5 miles...my speedo guage takes off and occulates between say 120 and 140. While it's doing this... it's making a very ugly (squalling dry bearing), sound. After doing this a few times, (from normal to my description), it settles down and work perfectly fine! Any ideas? Muddy
Old Nov 21, 2007 | 01:07 PM
Durango_Boy's Avatar
Durango_Boy
Sounds like you need to pull out your speedo cable and lube it up. Not too bad of a job if you don't mind digging in behind your driver's side dash.
Old Nov 21, 2007 | 01:12 PM
Muddywaters
Yep, I should have included...before, I put the dash all back together... I used (plenty) graphite lub on the tach drive cable and the speedo cable. Muddy
Old Nov 21, 2007 | 04:11 PM
sjr1971's Avatar
sjr1971
If you had the speedo cable disconnected then it is not fully seated. You will damage the speedo and/or cable if you don't go back in and reseat the cable. You should hear a click when it seats.
Old Nov 22, 2007 | 12:37 AM
Muddywaters
SJR: Seems strange, as we now have over 12K on the restore with no problems...ummmmm. Sure hate to go in there again Thanks Muddy
To Speedo goes WOT!
