Flex Bumpers
Old Nov 22, 2007 | 07:02 AM
Puckboy's Avatar
Puckboy
Default Flex Bumpers
Have been out of the Post for a while. I am ready to replace my 75's bumpers. I have seen the flex bumpers at Ecklers and on Ebay any suggestions.
Old Nov 22, 2007 | 10:01 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would stay away from Ecklers. They are not the company they once were. The original type may still be available from the General.
Old Nov 22, 2007 | 11:15 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Where are you located? I have one sitting here you could check out.
Old Nov 22, 2007 | 11:20 AM
wnmech's Avatar
wnmech
I just installed both flex covers from Ecklers and I am happy with their fit and quality. I had a new toledo pro flex cover that kept cracking and they replaced it and it cracked thats why I went with Ecklers.
Old Nov 22, 2007 | 11:26 AM
jd1a's Avatar
jd1a
I'm using Ecklers bumpers on my 75. The rear is on and worked good. I haven't started the front. I do have some repair to the right front fender. Previous owner must have bumped something.
Old Nov 22, 2007 | 12:25 PM
Puckboy's Avatar
Puckboy
Thanks for the info, MA little far from here in IL
Old Nov 22, 2007 | 12:26 PM
Fastguy's Avatar
Fastguy
If you look out the window and squint real hard.....
Old Nov 22, 2007 | 01:20 PM
colin75's Avatar
colin75
I REPLACED MY REAR WITH A FLEx FIT I PURCHASED FROM EBAY. NEEDED A FEW MINOR ADJUSTMENTS TO FIT WELL. DIDNT NEED ANY PREP IT WAS SMOOTH. OVERALL VERY HAPPY. JUST A NOTE YOU HAVE TO REMOVE 4 METAL BUMPERS AND LIGHT BUCKETS FOR THESE TO FIT. YOU CAN ALSO USE BOLTS WITH WASHERS IF YOUR BOLT STRIPS ARE RUSTED AWAY.
Old Nov 22, 2007 | 01:25 PM
MN80Vette's Avatar
MN80Vette
I have a rigid fiberglass bumper cover in front and flex glass cover in back, both from Ecklers. No problem with either in the 4-5 years they've on, and mine are mounted seamless. I don't know for sure, but I'd think any problem with the covers would would show up early with a seamless mount.
Old Nov 23, 2007 | 05:33 PM
1996vetteLT1's Avatar
1996vetteLT1
3rd Gear
I used the flexible fiberglass bumpers from Mid America Motorworks. I put them on a 1977 and they fit really well. Alot better than the original urethane bumpers.
http://www.mamotorworks.com/corvette?frame=1.1330
Old Nov 24, 2007 | 05:54 PM
pik's Avatar
pik
Hi Puckboy, where in Il are you? I have a 79 rear urathane piece that you can have. Came off my 79, needs work but you can't beat the price.
Old Nov 26, 2007 | 06:32 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Hey Puckboy, I,m in Bradley Il. Just put True-Flex front on my '74. It fit great! Good luck!
Old Nov 26, 2007 | 08:55 PM
ragtop00's Avatar
ragtop00
jbaron,
Where did you get the flex front for your 74? You said yours fit great...that's my next project and I don't like problems. Was it a good price? Is there anything I should be thinking about before I tackle this project?
Mike
Old Nov 27, 2007 | 05:04 PM
jbaron's Avatar
jbaron
ragtop00
Got my True Flex from Wilcox. And the price was pretty good. They have a special discount section on their website for Forum members.Good luck! Jim
Old Nov 27, 2007 | 05:21 PM
Puckboy's Avatar
Puckboy
Thanks for all the info/and bumper offer. I want to keep it a 75. I am the original owner.
Old Nov 28, 2007 | 10:28 AM
ragtop00's Avatar
ragtop00
Thanks jbaron
To Flex Bumpers
