Super M22
If a stock L-88 was drag raced with an M22 and 10 inch slicks, I'd put the over and under at 10 for number of passes before a stock M22 pukes (I'll take the under).
FWIW...
I doubt that my M22 will ever break with my combo and it has something around 450 lbs of torque.
Tell me if you see any Torque ratings published....
Paul
What are you supposed to do as a consumer, build a 600 tq motor and throw any tranny in there, the reason I bought the TKO600 was because of the torque it could handle not the overdrive, after I blew 2 Super T10 trannys
Here is what YOU can do to educate yourself about torque ratings....
Call up a company that publishes ratings and ask them about how they arrive at those figures. In fact, a company such as Tremec is perfect since they have different model transmissions with different ratings. After you are done trying to get a realistic answer from some engineer as to why the algorithms for a T5 in determining torque capacity are totally different then a T56... then how can one really compare apples to apples?
I would question how he gets 850HP rating out of a Muncie tranny which was rated stock at less than 400ft/lbs probably closer to 300ft/lbs
I have replied to posts on this forum about OD sets so please search. I've installed them for drivers, but in no means is it a performance set or really such a great upgrade.
In regards to chassis dynoed ratings, these don't mean much.
Different Rear axle ratios load transmissions differently with the same output from the engine, as do tires and clutch types. FYI all published ratings are a life factor rating... meaning that transmission CAN be subjected to bursts of said published rating over a calculated life of the transmission.... which they never tell you, thats why you need to call up the people who publish these ratings. You can EXCEED THE RATING.... you'll just shorten the life factor. These ratings are not STATIC applications such as sticking a breaker bar on the input and locking the output and applying a load until something snaps.
So just because your Muncie or TKO sees 800 Fts lbs... really doesn't mean much. The logic if one can understand this is simple....
If I do 3 passes at the drag strip with a engine hittin 800 Ft lbs of torque and the trans survives....does it pass and rate at 800FT Lbs? Now on the 4th run it scatters in a million pieces.... does it fail? This is where the life factor comes into play.
When it comes to the new Muncies which I happen to sell quite a bit of, in fact more than anyone... I just ask the customer what Horse power and axle ratio they are running. 600HP with a 3.08 and M22 probably not a good idea, but with a 4.11, no problem. There are quite a bit of the new Muncies out there in the 4 years they have been made. More than most people think. Realistically speaking, you are going to see some breakage. I've only seen 4 of mine in 4 years break and they were in cars with over 700HP and either a dead 3.08 rear or with a tilton triple disc clutch against a big block road race application. I expect these to break again because they fall out of the window I like to see them run in.
Paul
So I look around and see the TKO rated at 650ft/lbs and now I don't blow transmissions anymore. Good thing they had a rating or I wouldn't have bought it and probably bought an "unrated" Muncie and blown that too, 'nuff said
And in the future I would appreciate if you would refrain from telling me how to educate myself about anything
If you had a killer race motor you probably want to step up to a beefier transmission. The ratings are only used as a ballpark figure and I am glad some companies bother to rate them, because I am a happy camper with my 650ft/lb TKO 600
speed compair in strength, I'm not a fan of overdrives so I'm
talking the 1/1. in a perfect world I would love to have a G-force,
I even like the fact its not syncronized, but at around $5000
for one, most likely Ill never be able to spend that much for just
a transmission.
Besides different gear ratios, what are all the differences in
the road race version and the street version. I'm just guessing that
the road race version has strait cut gears the street might not.
Don't care anything about gear whine thats fine with me.
Comparing it to a T-10 is ridiculous. I know the M22 can handle the abuse of a 600 HP engine. Yes, it will puke its guts out eventually, but tell me what part of a car doesn't break after its gets abused time after time after time. The M22 is tough enough to handle drag racing and such, but people have to remember that it was road racing tranny! It seems to me people are more busy trying to bash the things of the old trying to make the new superior...
Also, I keep seeing about the M22 having a straight cut gear. This would be the M20... The M22 was an angled cut gear with a slight curve in it. That is why when you backed off of the throttle, the M22 would talk to ya.
"I would question how he gets 850HP rating out of a Muncie tranny which was rated stock at less than 400ft/lbs probably closer to 300ft/lbs"
Since we are talking about the M22, I am guessing your not talk about the M20 or M21.
"Here is how I educate myself, when I put 500ft lbs through a Super T10 rated at 300ft/lbs and blow it on the first WOT pass I pretty much figure the tranny blew because it was only rated at 300ft/lbs so it doesn't surprise me."
Now your talking about the T-10 being rated at only 300 ft-lbs when we are talking about the M22. Earlier, you mentioned an M22 to be rated at closer to 300 Ft-lbs. So it appears to me, that you were talking about the strength and integrity of the M22, through your bad eperience with the T-10.
If I am wrong, I apologize for my misunderstanding..
The second statement above the conversation had changed to why or how transmissions were rated for torque in general. I was trying to get across I am glad some companies rate their transmissions and I used the Super T10 and TKO as examples of why I liked companies to rate their transmissions.
Anyway I am out of this one, I am happy the way things are
