Backfire
Old Nov 24, 2007 | 03:13 PM
hgm's Avatar
hgm
Default Backfire
I have a 78 with a stock 350. @ wot it is breaking up and backfiring through the carb. At part throttle I have no problem. Wires, plugs, cap, coil and fuel pump are less than a year old. Timing is ok.
Old Nov 24, 2007 | 07:20 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
What is the timing exactly? Initial and @ 2700 rpm...
Old Nov 24, 2007 | 10:41 PM
hgm's Avatar
hgm
Initial is at 4 degrees BTDC
Old Nov 25, 2007 | 02:50 PM
BigBlockk's Avatar
BigBlockk
The carburetor is leaning out at WOT and you need more initial advance. Like say 12 degrees BTDC. Then you can begin the tuning process.
BigBlockk
Later.....
Old Nov 25, 2007 | 02:56 PM
jerome1979's Avatar
jerome1979
BigBlockk
Later.....
To Backfire
